Hi,
My 2000 Explorer FWD needs the right side upper ball joint (2 piece control arm and ball joint)
I read a post somewhere that said they made a one piece right side upper arm.
Advanced Auto sells the one piece control arm. It looks identical to the single piece left side. It's even stamped "R". By using this you won't have the adjustments like the 2 piece unit. Is this the right part? Advanced says that its the right part. Is this true?
Thanks, Angelo
MOOG still makes the outer half of the two piece replacemet.. Go to an aftermarket parts store that carries that brand (car quest works) and make it easy on yourself.. good luck
Yes I have the MOOG right side two piece arm. JUST the upper part is $167 from Lee Auto .. BUT after it goes out again you can use MOOG replacable ball joints in the arm. But $167 was rough.
