Upper Ball Joints/Control Arm 95 Explorer EB
Old Aug 5, 2004 | 11:27 PM
dwbab's Avatar
dwbab
Anyone changed the upper ball joints/control arms (the come as a unit) on a 95 Explorer EB 4WD ??
I have bought both sides and already changed the left side.
The original on the right side is a 2 piece control arm (as the manual shows)
that has what looks like a caster adjustment on it.
The new one for the right side is one piece without the adjustment.
Should the replacement be a 1 or 2 piece unit ?
Any help appreciated !!
Don
Old Aug 6, 2004 | 06:32 AM
95EXPLEDBAU's Avatar
95EXPLEDBAU
I did it few months ago, seems like the aftermarket arms are one piece. I never checked with the dealer, so I don't know if they changed their design as well. I had it aligned right afterwords and everything went fine. Weren't those cam bolts a huge PITA?? While you're at it I would check inner/outer tie rods and lower ball joints if you haven't replaced them yet.
Old Aug 6, 2004 | 09:06 AM
dwbab's Avatar
dwbab
Thanks !
Do you or anyone else recall if the original one for the right side was a 2 piece
wishbone ...... with an adjustment bolt for what looks like adjusting the caster? It looks like the new 1 piece (without adjuster) will fit OK but
I'm just concerned that they have given me the right replacement part .
Thanks again
Don
Old Aug 6, 2004 | 09:21 AM
95EXPLEDBAU
Yes, the original was 2-piece and replacement 1-piece. Thay gave you the right part. Like I said I had it aligned after I replaced it and it checked out OK.
Old Aug 6, 2004 | 09:36 AM
dwbab's Avatar
dwbab
Cheers ! Thanks for the info.
I'm heading back out the garage to do the right side .... and YES the cam bolts are definately a monster PITA !
Old Aug 7, 2004 | 08:49 PM
dwbab's Avatar
dwbab
Thumbs up
At another forum some mentioned that their replacement was a 2 piece unit.
Thought I'd better check with NAPA.
Looks like NAPA screwed up with part #'s.
The correct one for the right side is a 2 piece arm.
All you need is the outer half to do the ball joint.
Took back the wrong 1 piece unit, picked up the proper
part ............. installed it yesterday.
Next stop >>> allignment shop.
Thanks guys
mikebabyak
Jul 12, 2015 02:01 PM
ag-ford-4x4
1997 - 2003 F150
21
Apr 29, 2015 08:41 AM
codger
1983 - 2012 Ranger & B-Series
Jun 16, 2013 12:37 PM
pete315
Aug 6, 2009 10:38 PM
scacho
Mar 17, 2007 05:09 PM
