I have some old 16.5" split rims I want to turn into the local steel place to be used on some future F series truck parts.
My question is can I cut the rubber off these rims or will doing this release the spring tension on the retaining ring causing them to shoot loose and cut my head off?
There was a place near me that I know dismounted split rims but that was at least 6 years ago.
Once you drain the air out of the tires there is no "spring" pressure left. They only install the wheels and tires in the cage when they are airing them up. Make sure the tires are flat before you start.
Usually it takes pounding with a sledgehammer to get the rings off. Most of them are rusted to the rim making them 1 peice in effect.
Split rims run tubes (because they don't hold air) thus you might salvage the tube for floating/tubing if you want. It has been years since I broke one down (I was a lot hog at a small town Ford dealership) but once they are aired out they didn't scare me, I just hammered away.
Check out this instructional (add your www. to the front)! Nicely done!!!
Not trying to be picky but if you have 16.5 wheels, they are not split rims,
what you have are probably 15 or 16" split rims, Let the air out of them and there is no danger, just a lot of work.
As long as the ring grooves are clean and the ring not twisted by a "Goober", assemble, add air till app 6 psi then check for proper ring seating. No biggie then just add air as it is safe.
You never want to drive that extra 1/4 mile on a split rim with a flat as you'll throw the ring, tire, tube and boot.
On F 250's they were 16" rims like 7.50 x 16 tires.
