460 swap
Old Mar 19, 2002 | 06:42 PM
brianwbo's Avatar
brianwbo
460 swap
Ok I'm replacing my 300 with a 460, it looks like my 300, has a front sump oil pan, does the 460 need to have the same, I measured the room between my 300 oil pan and the crossmember I have like 3 to 4 inches of clearence, the 460 came out of a lincoln.
Old Mar 19, 2002 | 08:11 PM
merc460's Avatar
merc460
460 swap
The 460 should also have a front sump oil pan, generally the vans had rear sump pans and later model pickups Eric
Old Mar 19, 2002 | 09:36 PM
ty1on's Avatar
ty1on
460 swap
if your planning to put a 460 in your truck you need to have a rear sump pan and a crossmember from p a w they sell the cross member. reply back for greater detail
Old Apr 22, 2002 | 02:16 PM
red65crewcab's Avatar
red65crewcab
460 swap
For a 2wd you'll need a front sump pan with the drain plug in the back. 4wd take the rear sump. You'll also need motor stands and mount from a 73-79 with a factory 460. Have fun It's easy with the right stuff.
Old Apr 22, 2002 | 03:44 PM
brianwbo's Avatar
brianwbo
460 swap
Well I got the mounts and everything ready, waiting for the transmission. It will not be long now, just waiting on some body work to be finished..Thanks for the help all.
Old Apr 28, 2002 | 05:39 PM
ty1on's Avatar
ty1on
460 swap
if your going to put a 460 in your truck you should go with a rear sump pan with the high volume ford racing oil pump. also like the other guy said you sould get the cross member from paw. repley back for more details...
Old Apr 28, 2002 | 09:50 PM
merc460's Avatar
merc460
460 swap
What year of truck are you swapping the 460 into. If its a 65/66 you should not need to buy any crossmembers just the motor mounts fron a mid 70,s pickup with a 460. Maybe there is something I am missing here Eric
Old Apr 29, 2002 | 09:05 PM
brianwbo's Avatar
brianwbo
460 swap
That was just someone telling me I needed a new cross member, But I do not, just the new engine tower perches and motor mounts. Currently the truck is getting painted and adding a tilt front end, better room for the blown 460.
Old Apr 29, 2002 | 09:50 PM
merc460's Avatar
merc460
460 swap
Who made the tilt front end is it fiberglass or steel
I know US Body works makes a fiberglass one It looks pretty nice on there web site Eric
Old Apr 30, 2002 | 06:43 AM
brianwbo's Avatar
brianwbo
460 swap
Yes the Tilt Front End is fiberglass, I already have it. Currently it is sitting in my garage all ready to be put on this weekend. Have got a hydralic actuator to open and close it. Will be ready for paint next week....And yes, it is from www.USBody.com
Old Oct 27, 2002 | 03:28 PM
caddygene's Avatar
caddygene
460 swap
Just to add to my other post to 450 swap. If you have any info for me please e-mail me---caddygene@siteone.net
Old Oct 27, 2002 | 06:09 PM
Matt66's Avatar
Matt66
460 swap
chincycoot
Aug 30, 2013 06:47 AM
dyingtolive
19
Jan 31, 2012 06:37 AM
jim collins
Apr 30, 2010 07:34 AM
7mpg302
Dec 3, 2008 06:17 PM
TJDREAMS
Nov 19, 2004 11:31 AM
