water in headlight assembly
Old Jul 26, 2006 | 04:01 PM
SKIRYDR's Avatar
SKIRYDR
1996 explorer xlt.....i have water in my passenger headlight. where did this come in? we have recently had heavy rains....is this possible? how do i get it out?
Old Jul 27, 2006 | 04:13 AM
gpyles01's Avatar
gpyles01
Buy a new Headlight Assembly!!
Old Jul 27, 2006 | 01:48 PM
sjwoody's Avatar
sjwoody
My 90 ranger did that a few years back. I carefully pried the front lens loose, (mine was glued plastic...be careful), I then cleaned the lens from the water deposits, then used a thin bead of silicone to put it back on. I didn't see any damage in the back plate and the gasket on the bulb looked good. I figured there was a leak between the clear plastic lens, and the black backing. No trouble since.
Old Jul 30, 2006 | 11:14 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Another thing you can do is drill a small drain hole at the lowest part of the lens. Sometimes you can disassemble them and reseal the clear lens, but more often than not you break them in the process.
Problem is the seals hold water in as well as it holds it out. Drilling a small hole (like 1/32" or smaller) will allow the moisture to eventually come out. Maybe not completely but it will help.
The only real fix is to replace the dang thing!
dmp1983
Nov 4, 2012 11:28 AM
rhino_160
Oct 5, 2010 03:59 AM
provosc
Oct 13, 2009 07:17 AM
reddevilf150
Feb 11, 2003 09:01 AM
SVO
May 13, 2002 03:16 PM
