Abs
Old Jul 28, 2006 | 08:30 AM
redrock233's Avatar
redrock233
Abs
2000 explorer the ABS light came on does anyone no what might cause it or has had the same problem. Going to do the basic stuff tonight any other info would be greatful.
Old Jul 28, 2006 | 05:32 PM
steve(ill)'s Avatar
steve(ill)
about 50% of the time it is the speed pickup on the rear axle pumpkin. crawl under the truck by drive shaft and reach on top to the front of axle housing. there is a plastic speed pickup with one screw anchor. it points at the ring gear and counts teeth. when it gets weak or dirty, it dont read right. many guys change the pickup, i have cleaned it and it will work for a month. i have change the rear alxe lube so it is cleaner and that works for 6 months--- just some info.
Old Jul 30, 2006 | 11:16 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
It's a $15-25 part. One bolt and an electrical connector. Much cheaper than an ABS diagnostic. And I'd say it accounts for about 80% of ABS lights on explorers.
Good luck.
