Sponsored by: Real Truck
moisture in headlights
Old May 12, 2002 | 10:15 PM
SVO's Avatar
SVO
does any one have a clue to why moisture gets into the headlight and in turn blows the bulb ,and how to prevent this any input would be helpful
Old May 12, 2002 | 10:57 PM
Monsta's Avatar
Monsta
Sit. Stay.
The housing itself is cracked.
The seal on the rear, where the bulb goes in, is letting water go past it.
Fix? Troubleshoot. Clean the seal thoroughly! and maybe even coat it with white lithium grease or vasoline just to ensure that it is sealing good.
Grab the hose. Soak it down. Still getting wet inside? Well, it's not the seal. Pull the lamp housing and start lookin'.
Old May 13, 2002 | 08:09 AM
Monsta's Avatar
Monsta
Sit. Stay.
Old May 13, 2002 | 03:16 PM
CEEJR's Avatar
CEEJR
Had the same problem in my 89 bronco. Quick fix was to drill a 1/8" hole in the bottom of the housing which allowed the moisture to dry.
Chuck
rlester
Escape & Escape Hybrid
Sep 1, 2014 08:05 AM
joey schaffner
2009 - 2014 F150
Nov 28, 2012 08:08 PM
tjprawitz
Oct 17, 2011 09:52 PM
rhino_160
Oct 5, 2010 03:59 AM
rweiss
Jul 13, 2005 12:41 AM
