headlights have moisture in them...
Old Oct 4, 2010 | 11:18 PM
rhino_160's Avatar
rhino_160
2000 Navi has moisture in the headlights... whats the best option?
can i pry them apart and reseal? or what? thanks
Old Oct 5, 2010 | 01:24 AM
Moto Mel's Avatar
Moto Mel
NO! NO! NO! Do not pry unless you want a pile of scrap plastic. Remove the headlight and drain the water, then dry the headlight with compressed air, then you can use your wife or G.F.s hair drier set on low to medium heat and blow through the hole for the bulb. then you can seal the edge seam with clear silicone using a small bead and then use your finger to smooth and press into any imperfections/leaks. Let it dry and clean off any excess silicone and reinstall. Don't forget to reinstall the bulb.
Old Oct 5, 2010 | 03:59 AM
alloro's Avatar
alloro
Whenever someone comes to me with this problem I just drill a 3/32" hole near the bottom at an upward angle, which alway keeps them drained and dried. The heat from the headlights helps keep them dry, as long as that drain hole is there.
Willy3805
Feb 18, 2020 03:48 AM
siyksoul
Oct 28, 2016 05:44 PM
good to doo
Jun 29, 2016 09:55 AM
wtourvil
2004 - 2008 F150
Apr 7, 2011 01:22 PM
