Exhaust "Blat"
Old Jul 24, 2006 | 01:13 PM
AerostarDad's Avatar
AerostarDad
Exhaust "Blat"
Ok guys...'78 Ford 460,rv-type cam,true dual exhaust. I'm getting a real annoying exhaust "blat,blat,blat" when accelerating at half throttle or more. Is there any way of getting rid of it or ,at least, toning it down?
Thanks
Old Jul 24, 2006 | 06:44 PM
RangerPilot's Avatar
RangerPilot
Sounds like a typical exhaust leak. Start the truck and carefully search under it from front to back, looking especially around the gaskets if any exist.
RP
Zach
Old Jul 24, 2006 | 08:02 PM
mike2112's Avatar
mike2112
If you've got headers, I'd check those gaskets first. They are always leaking.
Old Jul 24, 2006 | 10:16 PM
AerostarDad
I'm running stock manifolds.
I'll check for leaks
Thanks all
If there are no leaks,whats the next step?
Old Jul 25, 2006 | 04:10 PM
RangerPilot
Small holes in the exhaust. A tiny hole on my buddy's S-10 made a very noticeable noise. After that you go into actual engine things that could be causing it.
RP
Zach
Old Oct 1, 2006 | 12:27 AM
AerostarDad
Well,thought I'd update y'all on my exhaust problems.
I just got an "X" pipe installed and,man did that ever clear up the "blat" problem. She sounds real smooth now,quieter with no "rapping" out the tailpipes. I'd recommend this to anyone who hates the "50's hot-rod sound" that the 460 makes when using a true dual exhaust sytem.
Thanks to all who had suggestions and tips!
1L243
Jul 11, 2015 08:34 PM
Mcrafty1
Jun 10, 2015 05:31 AM
RubberDuck
Exhaust Systems
Jul 6, 2007 12:25 PM
zsir
45
Sep 1, 2005 12:30 PM
moose94
Exhaust Systems
62
Jan 27, 2005 10:55 PM
