4" Exhaust
Yes, you will get the full effect by running stock up-pipes with your 4" system. It has already been determined that a 4" exhaust will handle your engines horsepower output to quite high levels. In other words, the only thing to be gained above 4" (for the vast majority of us) is a difference in both sound and appearance.
As for the up-pipes... they are very short, and that means that the pressure drop (friction loss due to velocity) across such a short piece of pipe is minimal. If you only increase the up-pipe diameter, you are still not changing the geometry of your turbo inlet housing and will still experience the same pressure drop through the entrance "nozzle" into the hot side of the turbo. If you do, however, also change your turbo inlet diameter to something ,larger, you are going to see a decreased gas velocity entering the turbo and your "spool up" potential will decrease (in other words, "lag" on the lower end of your acceleration curve, or sometimes called "slower boost development").
The whole "exhaust size" issue has to be designed to properly manage the gases' resistance to flow (back pressure, or pressure drop through both 1- the entire system, and 2- at each component). For optimal flow, you need to keep your gases flowing in a "linear" flow pattern with minimal-to-no turbulence inside the pipes while simultaneously having a large enough pipe diameter to create minimal friction losses due to the gas velocity. Obviously, your pipe diameter never changes over the range of operating conditions when you're running your engine, and that means you will get varying conditions based on the amount of fuel being burned and the volume of gases generated by the combustion dynamics. In other words, you will end up with a system which WILL give you linear flow with minimal friction losses due to velocity at some range of performance, but that set of performance characteristics only exists within a small range of exhaust gas flow (i.e. how much fuel is being burned, or, how fast your pushing your engine). It may be ideal while hammering the throttle, but would then be much less than ideal at normal highway speeds and normal acceleration levels, or vice-versa. You have to choose whether or not you're interested in fuel economy or power performance in a racing or towing setup... one will always be sacrificed to some degree by the other, regardless of which you choose.
Just for fun, below is some additional information I got from talking with the old Pinnacle Racing team several years back.
In Pinnacle's research and testing on exhaust design details, they discovered that if you increase your exhaust pipe diameter too much and too early (before adequate cooling takes place), you can actually create a zone of turbulence inside the exhaust system and increase your back pressure. Consequently, their down pipe for the 7.3L engine started out at stock size and only increased to 4" about half way down the length of the down pipe, and that was all in order to best manage the issue of back pressure by keeping the gas velocity "linear" throughout the entire 4" system (no turbulence to create the extra resistance to flow out the back end). Their testing was done primarily on race engines, though, so we more "common folk" will probably not ever realize the downside of this reality by going from a 4" to a 5" system.
Now... get a bigger intake, cap the wastegate control line, then do a turbo-back 4" exhaust, and you can see the boost reach the point of defueling the truck with stock everything else. Chipping makes the benefits of 4" more substantial.
As for the up pipes, they can take it. The pressures involved there make the pipe size less important than when the pressure is released and unrestricted low-pressure flow is key.
EDIT: Dang it, I can't rep you yet!!
to the O P if your exhaust is good you could just get rid of the stock muffler, search for the Big Truck Muffler (BTM) several threads on it. Personally I wish I'd have known about it before I wasted $$$ on a 4" exhaust but ...
I'm quite pleased with my 4" MBRP Turbo-back with Ford AIS intake. Unfortunately, I don't have EGTs before/after to share.
All I'm getting at with the exhaust is that with a truck like mine with stock injectors there really is nothing needed but to get rid of the 2 ton muffler & replace it with a straight through design. Don't get me wrong I really do like the sound of my Banks 4" turbo back exhaust but idk if I would spend that money again & cut up a perfectly good exhaust lol
