Take a look at Lisle's 34400 pipe expander, with the added collets it will extent the range to 4 1/4".
I have this with the added collets and use a hydraulic ram instead of a impact gun.
Best to get near the finished size then rotate the tool 1/8th turn remove the 4 segment expanded pattern.
This should help ya, go to; http://www.northernautoparts.com/Pro...?Productid=649 They go from 17510 to 17550 plus they have the 34400 expander.
I use a Greenlee pump from a Greenlee GL-7806SB QuickDraw kit I have; http://cableorganizer.com/greenlee/h...nch-driver.htm For some reason the photo doesn't come up you'll have to hunt around this forum.
I made a extended arbor out of two old ones to use this pump instead of a impact gun.
Do not order the Lisle 32500 and 32750 expanders unless your only expanding
wet toilet paper rolls as they are useless for exhaust pipe trust me I have both.
