What gears do I have?
Old Jul 23, 2006 | 09:08 PM
WhëëlMå1's Avatar
WhëëlMå1
Well I cannot give you photos of this procedure on one of the newer 04+ trucks, but check out this link (http://www.performanceunlimited.com/projectmpg/). You will see how the OEM intake setup, when thermally wrapped, beat all of the other setups tested. The thing with aftermarket air intakes is that they may flow 10000% more than the OEM, but they filter like crap. The OEM provides more than enough CFM of air to the motor, and filters so much better.
Old Jul 23, 2006 | 09:11 PM
Cavtrooper06's Avatar
Cavtrooper06
WheelMA1...wasn't there a thread on here about removing a tube within the stock intake assembly and then wrapping it?
Old Jul 23, 2006 | 09:13 PM
WhëëlMå1's Avatar
WhëëlMå1
I know some had removed some inner baffling, but I dont know if wrapping had anything to do with it.
Old Jul 23, 2006 | 09:17 PM
TRX250R87's Avatar
TRX250R87
K&N
So are the K&N filters that just replace the stock filters any good? I used to race motocross and was never a big fan of the protection that K&N filters provided!
ERIC
Old Jul 23, 2006 | 10:02 PM
WhëëlMå1's Avatar
WhëëlMå1
The OEM filters will flow enough for your motor, as well as offer superior filtration in comparison. I wouldnt even swap.
Old Jul 23, 2006 | 10:25 PM
1979FordF-250's Avatar
1979FordF-250
Talking
Originally Posted by TRX250R87
Any pictures of this modification?
I reccamend taking your truck to a good muffler and custom exhaust place. Muffler tech does good work. It costs less to have them make you a custom exhaust then to even buy a system. Then you would need to pay for instalation. I paid $235.00 for a flowmaster 50 series and a crome exhaust tip all installed. It costs less because all they do to a single exit exhaust is replace the muffler and put on a tip and reuse most of the still new factory tubing.
as for intakes I would reccamend any one of these K&N Intakes.
http://store.summitracing.com/egnsea...115+4294840115
Old Jul 23, 2006 | 10:33 PM
TRX250R87's Avatar
TRX250R87
mods
In what order would you recommend replacing the intake, exhaust, and tuner if I were to do them 1 at a time? I'm mainly concerned with MPG right now!
Thanks,
ERIC
Old Jul 23, 2006 | 10:39 PM
Cavtrooper06
Exhaust, tuner, intake.
ufvj217
Nov 22, 2012 02:30 PM
albuqtmt2
1983 - 2012 Ranger & B-Series
Nov 28, 2011 09:17 PM
Pimpfury
1997 - 2003 F150
Mar 8, 2009 01:09 PM
kupiec20
Feb 22, 2009 07:05 PM
daypray1
2004 - 2008 F150
May 20, 2008 05:51 PM
