General Diesel Discussion
Dodge
Old Jul 23, 2006 | 10:50 AM
copper's Avatar
copper
Question Dodge
My father Has a 99 dodge with a cummins engine. He bought a 35' 12000lb fifth wheel to travel in the truck has a standard trany. I would like to know what everyone thinks he should have for guages. The engine has a turbo. I think he should have a boost and egt guage but I am not sure about a trany temp guage.
Old Jul 23, 2006 | 10:51 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
you dont need a tranny temp gauge for a manual transmission. boost and pyro is all he should need.
Old Jul 23, 2006 | 01:30 PM
MAKO314's Avatar
MAKO314
a new truck would be the first of my concerns, not the trans temp
Old Jul 23, 2006 | 01:33 PM
Cuda_jim's Avatar
Cuda_jim
That had to happen.
Old Jul 23, 2006 | 06:25 PM
Kwikkordead's Avatar
Kwikkordead
Thread moved to General Diesel.
It would be good to have a transmission temperature guage for that manual >if< it does not have a transmission cooler like our ZF6 has.
Another suggestion is a differential temperature guage. The Cummins makes it's power at a much lower rpm than our PSD's and they gear them higher to make up for it. That translates into much higher pressure being applied to the hypoid gear in the rear axle which makes a lot of heat.
Old Jul 24, 2006 | 08:04 AM
nevrenufhp's Avatar
nevrenufhp
EGT, boooost, and fuel pressure. The 98.5 - 02 models have a weak lift pump. If the fuel pressure gets too low, it'll fry the injector pump. If you do a search for the FASS system, it's a real nice alternative to the stock junk. It means Fuel, Air, Separation System.
fordka
Oct 20, 2015 08:37 PM
KH85
Aug 11, 2011 01:34 PM
PSD2005
Nov 20, 2010 03:32 PM
dodge2003
Ford vs The Competition
73
Mar 20, 2006 12:02 PM
TallPaul
16
Mar 12, 2001 09:32 AM
