Modular V10 (6.8l)
Buzzing noise
Old Jul 23, 2006 | 09:15 AM
Kennicol's Avatar
Kennicol
Buzzing noise
This weekend I notice sometimes when the transmision shifts before 30 or 40 mph there is a slight buzzing noise. Does not happends all the time and does it when towing and when not. Other than the noise seems to shift all right truck has 66700 miles on it transmission was rebuilt at 37000 when 2nd went out it is the 4r100
Old Jul 23, 2006 | 02:50 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It's the inspection-cover on the front of the bellhousing. It likes to vibrate.
Take it off, put some stick-on rubber/foam on the top front edge and re-install.
Old Jul 23, 2006 | 09:41 PM
FortyFords's Avatar
FortyFords
Might be a loose heat shield also.
Rich
Old Jul 25, 2006 | 07:26 PM
Kennicol's Avatar
Kennicol
Thanks for the info I found a spot weld on a heat shield broken and I also put the strip on the inspection shield
Goaltender46
Jul 19, 2013 09:16 AM
sammie0126
Nov 10, 2012 06:14 AM
RNH Performance
May 10, 2011 08:37 PM
mongo12
Feb 3, 2010 10:23 PM
dirtworker
Mar 2, 2008 07:38 PM
