what is this buzz?
Old Mar 1, 2008 | 12:20 PM
dirtworker's Avatar
dirtworker
what is this buzz?
when i turn the key on and wait for the glowplugs the engine buzzes then the abs makes some noise too. what exactly is buzzing in the engine? injectors?
Old Mar 1, 2008 | 01:28 PM
cartmanea's Avatar
cartmanea
Its the fuel pump.
Old Mar 1, 2008 | 01:53 PM
dirtworker's Avatar
dirtworker
no, the fuel pump is under the driver's seat, this noise is in the engine compartment
Old Mar 1, 2008 | 01:54 PM
UGA33's Avatar
UGA33
vacuum pump
Old Mar 1, 2008 | 01:59 PM
dirtworker's Avatar
dirtworker
its not the vacuum pump either, its coming from the engine like the injectors are buzzing, don't tell me no one elses does this
Old Mar 1, 2008 | 02:04 PM
UGA33's Avatar
UGA33
Have you popped the hood and let someone else start while you listen
Old Mar 1, 2008 | 02:56 PM
dirtworker's Avatar
dirtworker
this is before the engine starts, i can pop the hood, turn the key on, and for about five seconds the engine buzzes, the abs buzzes, and the vacuum pump comes on. i am just wondering what in the engine is doing the buzzing. do the injectors cycle before starting?
Old Mar 1, 2008 | 03:44 PM
cartmanea's Avatar
cartmanea
Its normal so why are you so worried about it?
Old Mar 1, 2008 | 05:01 PM
mhoefer's Avatar
mhoefer
Injector cycling prior to startup is normal.
Old Mar 1, 2008 | 05:44 PM
Mustangbru8's Avatar
Mustangbru8
mine does it, I don't know what it is either
Old Mar 2, 2008 | 12:32 AM
tippmann87's Avatar
tippmann87
Does it only do it when your "Wait to start" light is on?
Old Mar 2, 2008 | 08:26 AM
dirtworker's Avatar
dirtworker
no one said i was worried about it, just curious what it was.
Old Mar 2, 2008 | 10:54 AM
slowmans's Avatar
slowmans
glow plugs...
Old Mar 2, 2008 | 01:46 PM
cartmanea's Avatar
cartmanea
Originally Posted by slowmans
glow plugs...
Electricity doesn't make noise, it has to be something mechanical.
Old Mar 2, 2008 | 03:14 PM
denman81's Avatar
denman81
its injectors, take your truck in and have them do an updated flash. your just hearing the injectors cycling, the new flash eliminates that and dose inductive heating instead.
