Power Add-on's
Old Jul 28, 2006 | 10:00 AM
  #46
MustangGT221's Avatar
MustangGT221
Originally Posted by Blurry94
which is why I think comparing motors and modifications
between EEC-4 F-150's and Mustangs is pointless.
But you can compair the basic general design differences between the two motors....such as different intakes, exhausts, cam, etc....and talk about what makes them different from eachother.
Pretty much what we've done here.
Old Oct 3, 2007 | 08:43 AM
  #47
supra89t's Avatar
supra89t
Ok, so I want to get a better idea of some actual mods and their results. Say I had a 1995 F-150 with the 5.0 (hypothetically, of course) and I had to change the intake manifold anyway for clearance issues. If I put a mustang HO cam and upper/lower intake (& TB), K&N air filter, some shorty headers and 2.25" exhaust with twin high-flow Magnaflow cats and a 2.25" DI/DO magnaflow muffler with tru-x core, what kind of power gains would you expect?
'95 is already a mass-air system with correct firing order. Fuel rail/injectors should drop right in, right? Are there any other supporting mods (the "Oh, I didn't think of that" mods) that would need to be done?
Thanks! Sorry to hijack/resurrect this thread, but the discussions have been great!
Old Oct 3, 2007 | 09:15 AM
  #48
Conanski's Avatar
Conanski
You should start a new thread if you have additional questions. That setup is very much how the mustang came from the factory, it will make 220-250HP depending upon how well the exhaust flows. Short tube headers are a waste if you are replacing the whole system anyway, and longtubes will boost low rpm TQ, something the 5.0 desperately needs in a heavy truck.
I'll add that since this thread was started, new information has come in. One of posters here had the oportunity to dyno a 5.0HO he put in his truck. It has a complete exhaust on it, possibly GT40 heads, but otherwise used the stock longblock. With the mustang HO intake on it made ~275hp.. which is consistent with other dyno figures I have seen for well equipped HO's. With the 5.0 truck intake it made just over 300hp.
Old Oct 3, 2007 | 02:21 PM
  #49
supra89t's Avatar
supra89t
I apologize. I thought that my question was in line with the discussions that make up this thread. Sorry. I didn't want to get told to search, so I just posted in the thread I though I was most likely to get referred to.
Its not going to be in a heavy truck. Low-end torque is good, though. The issue is going to be clearances in my engine bay. I have been told the truck intake is too tall and will hit my hood. I don't know that long-tube headers will clear my frame rails. If space wasn't an issue, those are the obvious choices for power.
Is that 300hp through the twin 45mm TB's of the truck upper intake? Nice. What cam was he running?
Thanks for your help. I, like most, am in search of a strong 302. I will share what I learn in the process and appreciate any help that others can offer me.
Old Oct 3, 2007 | 02:46 PM
  #50
Conanski's Avatar
Conanski
OK then.... the 5.0 feels pretty torquey in something the weight of a mustang, if you project is of similar weight then the extra hastle of longtubes may not be worth it.
If I remember correctly, it was a stock HO bottom end, stock HO cam, and GT40 heads. Also that was with a stock truck intake. The HO intake has known limitations. The TB neck is restrictive, and some of the lower intake runners are cramped. It generally needs porting to get beyond 260-275HP. The truck lower is much better, and if you can find a Holley Systemax upper it will match. If you were going to run a blower you could also combine a simple breadbox upper with the truck lower, this combo can make silly peak HP numbers with high flowing heads. If not, anything from an Explorer intake to one of the many car style aftermarket intakes will reduce overall intake height while offering much better flow.
Old Oct 3, 2007 | 04:31 PM
  #51
supra89t's Avatar
supra89t
What accounts for the difference in HP and TQ numbers from the HO mustang motor to the non-HO truck motor? Is it just the cam/intake/exhaust causing the difference? The truck makes less power and less torque. With a good intake, good full exhaust and a mustang HO cam (truck already has E7 heads), will this motor make more power with the truck mani than the mustang mani? It sounds like you are saying yes, but I like to ask the same question 3 different ways to make sure I understand. My wife hates it. lol.
If so, it may be worth the time to try and fit the truck manifold.
Old Oct 4, 2007 | 08:30 AM
  #52
Conanski's Avatar
Conanski
Yes, its just the cam intake and exhaust accounting for the difference, all other parts are identical(HO used forged pistons but CR was the same).
When considering intakes though, you should look at the whole powerband, and not just the peak HP numbers. The truck intake may make more peak HP.. as will just about any other intake, but because of the large volume intake runners low rpm air velocity is down and as a result low rpm TQ is less than it could be. The HO intake may make ~25 fewer ponies at 5000rpm, but air velocity through the intake will always be higher, and as a result it will make more torque below 3500rpm, so on the street it makes for a better performing motor. There are more than a few people that got all carried away building a 5.0 for 300+HP with high flowing intake and heads, and then complain that the motor is completely gutless below 3000rpm. If you want those big HP numbers, then bump the compression to 10:1 or more to regain some of the lost TQ, or use a blower.
Old Oct 4, 2007 | 04:24 PM
  #53
supra89t's Avatar
supra89t
Thanks, Conanski! That helps a bunch. I have been going back and forth on which parts I want to use on this motor. I am not going to be making more than 250hp anytime soon, so I guess I will stick with a mustang HO cam and intake b/c it will be a better powerband than the truck cam and intake. Under 250hp, I would imagine that the peak figures would be pretty close, 10-15hp max difference between the two setups.
Would it be easier/just as good to do a set of 1.7 roller rockers on the truck cam as swapping in a mustang HO cam? Its a '95 mass-air roller motor. Or would the mustang cam with the original truck rockers be better? Are the rockers the same ratio on the truck as the mustang?
Old Oct 4, 2007 | 06:55 PM
  #54
flareside_thunder's Avatar
flareside_thunder
Like Blurry said...idfferent vehicles with different purposes in mind....would you gain something just by swapping overto MAF anyways?I'd think it would be a little more economical in the longrun and get you some better mileage as well......This discussion has been VERY enlightening and I cannot wait to start working on my 95......I've already got the exhaust done but I'm"upgrading" to true duals with dynomax race only bullet mufflers....a mild cam,gasket matching,port/polish on the heads and longtubes......can't wait to see what it does after that....then I'llhave to start beefing the tranny and probly gonna change the gears.......but that's another thread in the future...thanks for all the info guys.
Old Oct 5, 2007 | 09:07 AM
  #55
Conanski's Avatar
Conanski
The truck cam is considerably smaller than the HO cam on the intake side in particular, and these motors really benefit from as much lift as you can get. I suggest the HO cam with 1.7 rockers. Both motors come stock with 1.6 ratio rockers.
Old Oct 28, 2007 | 05:01 PM
  #56
flareside_thunder
Alright Paul....but will the 1.7's clear the stock valve covers or not?
JR
benmoderow
Mar 8, 2011 08:11 PM
FX4Range R
Modular V10 (6.8l)
17
Mar 6, 2009 01:59 PM
maschronic
23
Aug 1, 2007 01:56 PM
Shovelhead 93
Aug 25, 2006 09:21 PM
scottlane
Exhaust Systems
Jun 12, 2006 09:47 AM
