1965 e-100 steering problem
Old Jul 20, 2006 | 02:55 PM
jarthur's Avatar
jarthur
Hi, I've got a 65 e-100 van that I've been doing a lot of work on. It's my daily driver and I love it! One thing that's been a problem since I got it on the road has been that the steering seems real squirley. I imagined it would be a little weird with everything being on top of the front axle like it is, but the front end is all over the place. Before I dig in, and have to be off the road for a while, could anybody point me in the right direction as to what it might be?
Thanks
Old Jul 20, 2006 | 07:55 PM
Jimbare's Avatar
Jimbare
all alone in the world
#1 alignment. is it ok?
#2 is the steering box good and tight, or is it sloppy?
#3 how are the tie rods and drag link?
#4 how are the kingpins?
i would jack 1 front wheel up and see if i had slack in the steering components by turning the wheel front to back. all you have to do is rock it back and forth to see if anything is loose. let someone rock the steering wheel and look at everything including the steering box it self. i have seen them work loose.
while you have it jacked up, try to move the wheel in and out on the top and bottom. if it moves it probably has worn out kingpins.
email or pm me if you have any questions about any of this.
Old Jul 21, 2006 | 10:09 AM
jarthur's Avatar
jarthur
thanks! I'm try all that this weekend.
Old Jul 21, 2006 | 10:39 PM
66gpw's Avatar
66gpw
My 64 E truck had the same problem. Stabilizer bolts and bushing were replaced. That helped, but I found the problem to be woren out Kingpins.
Have the van on stands on the axle. Have someone grab the top and bottom of the tire and push them back and forth. While you look at the kingpin. If you see even the slightest movement at the top or bottom they need replacement. It is amazing how that small movement can make the van rove all over the road.
Old Jul 23, 2006 | 09:11 PM
Jimbare's Avatar
Jimbare
find anything?
Old Jul 24, 2006 | 10:37 AM
jarthur's Avatar
jarthur
I didn't get a chance this weekend. Worked on motorcycles all weekend. The van is next!
Old Jul 26, 2006 | 06:02 PM
Jimbare's Avatar
Jimbare
let us know what you find will ya. might give someone else a starting point for theirs!
Old Jul 28, 2006 | 10:00 PM
R Pope's Avatar
R Pope
I-beam front ends often get vague when the springs relax with age and the caster gets decreased. An alignment and some wedges between the springs and axle will fix it.
Old Sep 18, 2006 | 09:58 PM
tsherry's Avatar
tsherry
Thanks
I have a '65 Falcon window van, and ended up replacing tie rod ends and the center link, off the shelf at Schucks/Checker. The steering box was another story...I finally found one at pro-steering (dot) com. Drives like a dream now.
pYr8
Feb 10, 2015 01:51 AM
Pele
Oct 13, 2014 12:38 PM
Boston James
Escape & Escape Hybrid
Feb 5, 2014 02:47 PM
bigfootsurfin
Aug 8, 2013 10:21 PM
jayjjcc
Jul 19, 2012 01:04 PM
