c7 e6ta ab ???
Old Jul 19, 2006 | 05:08 PM
jimandjimmer's Avatar
jimandjimmer
c7 e6ta ab ???
Found this on a tag on front axle..can anyone decode it? Also anyone know where i can get a complete engine wiring harness for a 86 f150 at a reasonable price??
*BTW the tag was covered in rust and thats what i made out of the bit i could read.
Old Jul 19, 2006 | 05:11 PM
Mil1ion's Avatar
Mil1ion
March 7th cast for an 86 (E6TA) Truck after a couple of changes from original design
Old Jul 19, 2006 | 05:26 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
3.07 ratio, 86 F150 WHAT ELSE YOU WANT TO KNOW?
Ed
Old Jul 19, 2006 | 05:38 PM
jimandjimmer
is this the dana 44? Also have any ideas which carb is on my 300 six? it has CARTER MADE FOR MOTORCRAFT and 2035 and 6-2037 cast in various places and 7051 SA its a 1 barrel.
Old Jul 19, 2006 | 05:44 PM
Parts Guy Wyatt
Former Vendor
yes,dana 44. unable to help on carb.
Ed
Old Jul 19, 2006 | 10:02 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
It's probably the Carter YFA 1 barrel carb.
Does it have a feedback solenoid on the side? Electical wires attached?
If it's non Feedback it's a Carter YF 1 Barrel.
There should be a metal Carberator tag simular to the distributor tag, and axle tags. located on the front. Probably with a number E6TE and a suffex on the end.
Example, the part number on the tag of my Carter YFA 1 Barrel Carb is, E1TE GC. It also has the marks... A-OK 30. It was A-ok'd by inspector number 30 etc...
If you don't have the original carb, or the tag is missing, you can have a "Friendly parts man at ford that isn't busy" run your Calibration code, found on the emission sticker.
or he can cross reference your computer part number, egr valve, and distributor part numbers to get a compatible carb number for you.
Not all Ford parts men are friendly though. I went to a Ford dealer out of town. the guy running the parts counter, instead of looking up parts for me and taking his time to help, he would just say
they are obsolete to get rid of me etc...
I then went to my local Ford dealer that I've been friends with, and taught some of their secrets from for 20 years and it took them 30 minutes, but they found the part I needed. It wasn't obsolete after all! Infact the part was used from 1975 to 1996! They just had to do a lot of part number cross checking, which the other man wasn't willing to do.
So just a heads up there. If you get a guy that wont even look the parts up for you, find one that will.
Hope this rambling helps.
Old Jul 19, 2006 | 11:31 PM
Mil1ion's Avatar
Mil1ion
I also have calibration codes/vacuum diagrams/specs & obsolete books if you can't get help in the outside world
Old Jul 20, 2006 | 09:47 AM
Parts Guy Wyatt
Former Vendor
81-F150, Very well said, so let me clarify my statement, "unable to help with carb"
I should have also stated with those id numbers, I was really busy at the time and did a quick check on carb, there are about 21 parts list for a 86 F150 4.9, so yes a Cal code or a tag off carb will get me to a parts list, but the way some of the catalog reads it still might not tell me exactly which carb it is but it will list the parts for the carb. so jimandjimmer is it a carb you need or a kit or a part of carb, or is it you just want to know what carb you have?
Ed
Old Jul 20, 2006 | 11:55 AM
Mil1ion's Avatar
Mil1ion
DFP,
But I have the book that does tell which carb it is.
Old Jul 20, 2006 | 01:14 PM
Parts Guy Wyatt
Former Vendor
mil1ion, cool !!!!
Ed
Schaffner
Feb 2, 2015 08:45 PM
sonny1965
Apr 17, 2014 04:26 PM
Scoop531
Nov 26, 2013 07:03 PM
Second79F250
Apr 27, 2012 10:43 AM
otpracer100
Jan 24, 2006 03:52 PM
