dist. problems
Old Jul 19, 2006 | 04:19 PM
GOTH_TRUCKER's Avatar
GOTH_TRUCKER
Exclamation dist. problems
ok i upgraded my dist in my 84 from the tfi to the ds2 dist. well,i got thedist out of a 78 xlt with the same engine and everything i orderd the dist,no problem,made sure when i got the dist all the mesurements were the same so i turned in the dist i got off the 78 in for core,got home went to slide it in, engine at tdc and it will slide in,but only to the point where the seal is like a 1/4 from going all the way in,wuts the deal,wut do i have to do to get this thing in,thx yall
Old Jul 19, 2006 | 11:24 PM
big hoss 29's Avatar
big hoss 29
Sometimes you have to just play with the rotor a little bit to get the gears to mesh with the gears on the camshaft. But whatever you do, don't force it, (bad mojo there).
Old Jul 20, 2006 | 05:46 PM
F150 hybred's Avatar
F150 hybred
I believe your going to have to change your oil pump drive shaft to the earlier version. the ones that came on the engines with the duraspark, had a shorter drive shaft. I could be wrong... it could be the other way. If someone else knows... a little help here would be appreciated. Both by the original poster and by me.
