6 codes
Old Jul 19, 2006 | 02:25 PM
inspector99's Avatar
inspector99
6 codes
i have a 96 f150,4.9 6 cyl,160000km.I bought a scanner and got codes p1130,p1150,p0383,p0174,p1507
What should i try replaceing first?
Old Jul 19, 2006 | 09:50 PM
inspector99
no body got any ideas???
Old Jul 20, 2006 | 10:23 AM
inspector99
i guess im on my own
Old Jul 20, 2006 | 11:45 AM
Scndsin's Avatar
Scndsin
Ford fault codes are either 2 or 3 digits. Since you've got way more plus letters, I'd have to say that they are unique to your scan tool & should be in its accompaning manual. It would appear no one recognizes it, hence no response.
Old Jul 20, 2006 | 12:01 PM
KW160's Avatar
KW160
96 uses OBD-II, so the codes are 4 digit.
Old Jul 20, 2006 | 12:31 PM
Scndsin's Avatar
Scndsin
My bad, I was going on FFI.com list. Thought that included OBD2 as well.
Old Jul 20, 2006 | 01:11 PM
inspector99
ok,heres the story...i cleaned the maf,iac,and changed plugs.The engine light hasnt come back on since i unpluged the battery,truck is working much better,not perfect,but better.
Plugged in the code reader anyway,got codes p0171,p0174 which i know is system too lean.Also got code p1401,differential press feedback egr circuit high imput.What the heck does that mean,i need to check the diff for fluid?
Old Jul 20, 2006 | 11:18 PM
inspector99
think i found the problem,bad DPFE sensor ,gonna try a new one
Old Jul 20, 2006 | 11:47 PM
parrisw's Avatar
parrisw
Yes it could be the DPFE sensor they can fail, but before you replace it, check the hose's that go to it, they are very common to split, melt, old and cracking, falling apart. If the hose's are bad replace them before replacing the sensor, otherwise your wasting your money.
Will
Old Jul 21, 2006 | 06:48 AM
inspector99
thanks ,ill give them a better look
Old Jul 21, 2006 | 04:31 PM
inspector99
all i did was change plugs and dist cap,dont get the p1401 code anymore,not yet anyway.i still get lean system bank 1 and 2 codes.checked out the hoses to the DPFE sensor ,seem ok...im lost now ,dont know what else to do
Old Jul 21, 2006 | 04:32 PM
inspector99
oh ya,forgot,i did clean the maf and iac,might need to clean the maf more
Old Jul 22, 2006 | 06:42 PM
inspector99
cleaning the MAF,helped,but now i get codes,171,174(system too lean)1401(DEFP)high output,and 1409( EGR Vacuum regulator solenoid)These codes are gonna drive me nuts.
Old Jul 23, 2006 | 09:06 PM
clstrfbc's Avatar
clstrfbc
What is the truck actually doing that prompted you to scan the codes?
the egr differential pressure still for the egr valve, means its out of position. There may be some carbon buildup on it. It can be cleaned too.
Go over the vacuum lines really close, around the egr too. Too lean is often a vacuum leak. If you have a propane torch, you can use it, (UNLIT) around the vacuum lines to check them. If the engine speeds you are close. Just be carefull.
Old Jul 23, 2006 | 09:27 PM
inspector99
The engine light came on and when i was driving it would run ok for bit,then just die out,barely run.It acted like it was out of fuel.The only way i could get it to run half decent was to spray throttle body cleaner in the air breather pipe,it would run fine for a short time but would do it again.Also,when i would put the peddle to the floor going up hill it would die out.Its working pretty good right now,but still some hesitation when i put it to the floor.
