Sponsored by: Real Truck
power window binding?
Old Jul 19, 2006 | 11:16 AM
kbeefy's Avatar
kbeefy
The front passenger side window in my '00 f350 seems to bind up about 1/2 way down. It powers up just fine. I took the door panel off last night, looked for obvious things and regreased the regulator. Didn't notice anything funny w/ the tracks, and the problem persists. Any tips?
thanks!
Old Jul 19, 2006 | 01:04 PM
FortFord's Avatar
FortFord
I don't know whats goin on but when ya find out post the answer cause mines doin the same thing.
Old Jul 20, 2006 | 10:04 PM
kbeefy's Avatar
kbeefy
bump for more help!
Old Jul 21, 2006 | 12:56 AM
Cowboy Brett's Avatar
Cowboy Brett
Well, see if this helps...
What you need to do is get ahold of some silicone aerosol spray (not form a gasket, just a silicone lubricating spray) at a hardware or auto parts store. If the window isn't clean, make sure you get any junk off of it and put it down. Then (with a rag handy!) you want to get that spray nozzle in real close to where the window goes up and down and spray in there. Do it from top to bottom. There's no need to take the door panels off. Once you're done, run it up and down a few times and wipe off the excess that gets on the glass.
You might also make it slide up and down a little easier if you put Rain-X on that glass when you've got it clean.
Old Jul 24, 2006 | 03:41 AM
Cowboy Brett
I figured it might be a good idea to give this one a bump in case nobody saw the reply. Any updates on the binding problem?
1994F2507.3L
Feb 18, 2014 07:27 AM
richartdana44
Dec 22, 2009 05:02 PM
papabills54
Oct 28, 2009 08:17 AM
Chorizo520
Electrical Systems/Wiring
Mar 28, 2009 04:37 PM
ColtM4
Dec 5, 2005 07:11 PM
