Power window binding
Old Mar 20, 2009 | 04:27 PM
Chorizo520's Avatar
Chorizo520
My passenger power window on my 2000 truck is binding. Goes down fine but up is so slow I think I might damage the motor. If I pull up on the rearward side it goes up fine too. If I lube the tracks regularly it works fine. Problem is I have yet to find a lube that does not leave film near the edge of the window. Also anyone know of a lube that last longer or somewhat waterproof? Or better yet how do I fix this frustration for good? Thanks guys
Old Mar 20, 2009 | 10:48 PM
Franklin2's Avatar
Franklin2
I would pull the door apart. You might have a small roller wheel missing or not turning.
Old Mar 22, 2009 | 04:07 PM
jimdandy's Avatar
jimdandy
Also, the gears in these things are plastic, and fail with age. Gear kits are available.jd
Old Mar 28, 2009 | 04:37 PM
Chance_Thomas's Avatar
Chance_Thomas
I had the same problem. Thought maybe the motor was going bad so I took it to autobody shop. I already did all the greasing of the tracks but that didn't. It was binding on the left side of the window next to the seal. He put some sort of oil on the outer edge of the window and it works like new.
7622RM
1983 - 2012 Ranger & B-Series
Dec 11, 2018 05:34 PM
bf5113x
Oct 19, 2015 07:02 PM
jnoble87
Jan 23, 2015 07:37 PM
Big-Red-Lariat
2009 - 2014 F150
Oct 30, 2014 02:59 PM
