Sponsored by: Kumho
Rag Joint (Coupler) Replacement
Old Jul 19, 2006 | 07:46 AM
jfarcas's Avatar
jfarcas
Hey guys, I'm working on a '76 F150 Supercab, 2wd. The rag joint that connects the steering shaft to the steering box is totally broken, so I have almost a half-wheel turn of play in my steering at highway speeds (kinda dangerous). I'm going to replace it, but haven't done one before and I haven't had the time to buy a Haynes manual yet.
Can anyone give me a rundown of how to replace the coupler? It look as though I'm going to have to move the steering shaft backwards towards the firewall in order to have enough room to slip off the old coupler, but I'm not sure.
Thanks! (I'll post some pics later today if it helps)
JF
Old Jul 19, 2006 | 11:15 AM
fordin K's Avatar
fordin K
just like that ! don't know if yours is riveted or nut and bolt, as soon as you separate both halves, the joint should be no problem.
Old Jul 20, 2006 | 10:37 AM
jfarcas's Avatar
jfarcas
Mine bolts together, and has two studs to connect with the steering shaft if the coupler bends too far or breaks (like mine did).
The reason I asked about having to move the shaft is because I figured it was secured also on the stering wheel side. Are you saying that after I disconnect the shaft at the joint, then I'll be able to move the steering shaft back with no problem?
Thanks!
JF
Old Jul 20, 2006 | 01:30 PM
73Custom's Avatar
73Custom
The steering shaft should not slide in the column. You will need to loosen the column from the dash, so the whole column can move back a couple inches. Once the column is out of the way, you may need to remove the lower portion of the coupler to be able to drill out the rivets that hold the rubber disk to the metal coupler. Most parts stores have a $10 kit with the disks and replacement bolts and studs. It's a pretty easy project.
Marty
Old Jul 20, 2006 | 05:00 PM
jfarcas's Avatar
jfarcas
Thanks Marty. I was going to return that 10.00 "HELP!! coupler, but maybe I'll just grind off the rivets and give it a shot. It would be helpful to have some tight(er) steering! The previous owner said it was like that when he bought it 10 years ago, and he never changed it - really amazes me how people deal with mechanical problems, eh?
JF
Old Jul 21, 2006 | 09:43 PM
jfarcas's Avatar
jfarcas
So, I tried to replace the coupler today, but couldn't get the column to move backwards at all. I took off the nuts from the joint, took off the cover plate inside the dash, loosened the two 1/2" bolts that support the column onto the dash - but couldn't get it to move. Do I need to pull the steering wheel?
(If so, it's no big deal - I think I need a turn signal switch as well)
Thanks!
JF
Old Jul 23, 2006 | 10:24 AM
Pickupmanx2's Avatar
Pickupmanx2
yep, pull steering wheel, then there is a bearing and bushings on both sides of column, top, in the cab, and bottom in enginecompartment, might want to see about replacing them to, makes a BIG difference also.
Old Jul 23, 2006 | 12:11 PM
jfarcas's Avatar
jfarcas
Sweet. Do you know what the bearings/bushings on the column are called so I know what to ask for at a parts store?
Old Jul 23, 2006 | 02:21 PM
Pickupmanx2
Not really sure, I did it a few years ago, steering column bearings? Ford should have a parts cataloge, or a breakdown at the stealership
tl1965
Nov 26, 2015 07:15 PM
95 Blk Bronco
Aug 5, 2012 04:12 PM
soco
Aug 12, 2008 09:08 PM
Snowman671
Aug 19, 2005 01:26 PM
timarkr
Mar 24, 2005 08:55 AM
