Rag Joint help
Old Aug 4, 2012 | 09:49 PM
95 Blk Bronco's Avatar
95 Blk Bronco
Rag Joint help
Just picked up a '76 F250 2wd with pwr steering. The rag joint was shot, so I picked up a Dorman/HELP 31004 to replace it. Well, I got the old one off, but the Dorman unit is too thick to fit. I don't have enough room between the splined lower shaft and upper steering shaft to fit the new coupler. I could barely remove the old coupler and it was basically just the splined coupler (rag portion disentigrated). How do I get this new one to fit? Is this the wrong part?
Thanks in advance for the help.
Old Aug 4, 2012 | 11:10 PM
400 .040over's Avatar
400 .040over
up under teh dash u have to lossen 2 bolts on the steering column so u can pull it back to make it easier.
Old Aug 4, 2012 | 11:21 PM
TexasTrash's Avatar
TexasTrash
As stated above, I had to loosen a few bolts then pull my steering column into the cab a bit to make room, then bolt everything together.
Old Aug 4, 2012 | 11:27 PM
95 Blk Bronco
Thanks guys. I'll give it a shot in the morning and report back.
Old Aug 5, 2012 | 04:12 PM
95 Blk Bronco
Loosened the 2 bolts and pulled the steering column down and back. After a lot of cussing, I finally got it to fit. Never knew it was going to be that big of a PITA. Steers much better now - very little play at all. However, my steering wheel is 45 degrees off. I measured and I can turn the wheel 2 full turns in each direction. Can I just remove the wheel and put it back straight?
Thanks again for the help guys.
jamesg139
Jul 23, 2013 02:15 PM
jfarcas
Jul 24, 2006 07:05 PM
jfarcas
Jul 23, 2006 02:21 PM
Triumph
Apr 5, 2005 09:19 AM
gearjammer26
Mar 12, 2005 04:59 PM
