Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
front end noise!!
Old Jul 18, 2006 | 05:03 PM
Brent M.'s Avatar
Brent M.
Question front end noise!!
another problem I'm having...(2001 V6 4x4 xlt)I did one front wheel bearing,the other seems fine...but when I turn sharp,and the vehicle rolls to the side that the new bearing is on(weight is on that side)I still get a bit of a growling noise...not so much a clicking,which I know is more the noise of a cv joint,but a growl type noise...any ideas as to what it could be?Brent m.
Old Jul 18, 2006 | 11:20 PM
bananaboat's Avatar
bananaboat
I'm not sure about a growl. A clunk in a slow turn could easily be the stabilizer links. A common wear component that's inexpensive and easy to replace. Since the growl is on the side that just had the bearing replaced, I'd suspect the replacement bearing may have issues - too tight?
Old Jul 19, 2006 | 08:03 AM
EBTDM's Avatar
EBTDM
It could be the tires, rotate them and take the turn again.
Old Jul 19, 2006 | 01:18 PM
Brent M.'s Avatar
Brent M.
thanks for the input...I tightened the bearings to factory spec's(can't remember what it was off hand)so that shouldn't be it...but i'll try the tire rotation idea!thanks again!
tonyevans69
Jan 19, 2008 08:30 PM
Brent M.
Aug 24, 2006 06:58 AM
Brent M.
Jun 12, 2006 11:40 PM
George2003
Jan 17, 2006 06:54 AM
