302 pulsating
Old Jul 18, 2006 | 12:53 AM
vaskel's Avatar
vaskel
302 pulsating
My '87 F-150 / 302 FI was runing fine until my alternator went out. Since replacing the alternator, the engine doesn't like to idle. It seems the problem is more apparent in warmer weather.
It starts fine, but it seeems like it is choked, and tries to die, but then it revs way up and persists in this pattern. Fuel consumption is a joke, and it smells like there is unburned fuel in the exhaust. It blows black smoke when first driven, but it clears up when the engine gets to operating temp.
Could this possibly be a faulty MAP sensor?... or something more sinister?
Thanks in advance...
Old Jul 18, 2006 | 01:10 AM
Dannym's Avatar
Dannym
does it run ok? if it's only idle then it's likely the idle control valve
otherwise, throttle position sensor, MAP sensor, O2 sensor, coolant temp sensor, or major vac leak from cracked vac lines or the steel "coffee can" vac reservoir behind the battery.
Actually you are almost certainly the coolant temp sensor. There are 2. One is a switch for the computer, the other is just for the gauges. You need the computer one.
Old Jul 18, 2006 | 01:17 AM
vaskel's Avatar
vaskel
Not really... it likes to intermittently try to die, even at highway speeds. It also does this when I use the cruise control.
ALl of my vacuum lines appear OK. It just seems odd that this problem 'appeared' after changing a major electrical compnonent.
Old Jul 18, 2006 | 01:30 AM
Dannym's Avatar
Dannym
There are connectors in that area that you might knock off.
Old Jul 18, 2006 | 05:20 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome vaskel, to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 18, 2006 | 09:46 AM
vaskel's Avatar
vaskel
302 pulsating
I just went out & checked for loose connectors and vacuum lines. All seem OK. One thing I did notice.. I couldn't find the PCV anywhere... lol
Old Jul 18, 2006 | 10:51 AM
306's Avatar
306
Start the engine, then disconnect the MAP while the engine is running, if the idle smooths out, the MAP is bad. The PCV is in the back of the upper intake manifold and connects to the passenger valve cover.
Old Jul 18, 2006 | 10:55 AM
Kemicalburns's Avatar
Kemicalburns
the pcv is on the back of the intake. check for codes www.fordfuelinjection.com will show you how and takes only a few mins. pull the vacum line from the fuelpressure regulator. if gas is present then its bad. also check your oil and smell the dipstick for fuel
Old Jul 18, 2006 | 06:49 PM
vaskel's Avatar
vaskel
Thanks for the info on the computer codes... I'll try that ASAP. Oil sump seems to be free of fuel (no discoloration and/or odors). FPR vacuum line appears to be OK.
Glaser67
Dec 30, 2015 01:37 PM
broncoderek
Oct 28, 2014 02:54 PM
Factola72
24
Apr 7, 2014 06:23 PM
Cole Monger64
19
Apr 3, 2014 05:25 AM
jonnygorgo
29
Mar 12, 2014 06:36 PM
