Sponsored by: Innova
Problem with
Old Jul 16, 2006 | 10:38 PM
Poohbear's Avatar
Poohbear
Problem with
6 disc changer in 02 F550. I bought this truck today and know nothing about it. when I put the disc in it will load but comes up with trk 1 and then shows seek and then back to trk 1 back and forth a couple of times eventually ejecting the cd . Has anyone ever had this problem and whats the best way to fix. Thanks for any help.
Old Jul 17, 2006 | 02:09 AM
FTE Trigger's Avatar
FTE Trigger
Is this an actual store purchased audio cd? Or something you "burned" at home? That sounds like the same symptoms that I would sometimes get on my OEM cd players after trying to load a "CD-burn gone Bad". Please forgive me for asking... But you are trying different discs?
If that doesn't work then its possible you have an "Eye" that's not looking where its suppose to be. Or potentially dirty.
For...A Last ditch effort you might want to physically unplug the radio for a few mins. Upon "start-up" it should do a quick internal scan and hopefully fix any minor inconsistencies...
Old Jul 17, 2006 | 05:58 AM
Poohbear's Avatar
Poohbear
Thanks for the reply, Yes I tried different cd,s nothing. I even put a cleaning cd in but no help. Do I have to unplug the player or can I remove a fuse or disconnect the battery.
Old Jul 17, 2006 | 06:16 AM
FTE Trigger
I often pull the radio to unplug it. I've never tried it any other way to be honest. It works well when it gets hung up in mid-button commands (mashing buttons too quickly)and relieving it of Stuck cds.
If that doesn't work its obviously Dealer time... A well established dealer should have a set of techs on hand that have had some training w/ Ford radios... that way you shouldn't have to worry about sending it out for an "internal" reset of some sort.
p.s....Bethlehem, Ga? Is that the one right outside of the Athens loop? You shouldn't be too far from Atkins Ford/Dodge... those guys seem like they know their stuff..
Old Jul 17, 2006 | 07:59 PM
Poohbear's Avatar
Poohbear
Yes we are near athens thanks for the help Ill try what you said if it dont work Ill look at going to AKINS dont want to. But sometimes you just got to bit the bullet.
Old Jul 17, 2006 | 08:12 PM
FTE Trigger
Good Luck!...
I hope it doesn't turn into spending more than a simple diagnosing fee...(if you need the dealership help)
killerlee
New Member Introductions
Nov 21, 2015 10:20 AM
newbietrker
Sep 20, 2015 03:57 PM
X36
Aug 27, 2013 11:11 AM
HMBLSRVT
Jul 3, 2006 09:21 AM
jetdocb747
Oct 6, 2004 12:41 AM
