97' "rough" idle
Old Jul 18, 2006 | 12:52 PM
viperrtblck's Avatar
viperrtblck
ok i gotcha now. so it's kinda like closed loop isn't it? but since this is an intmitent problem, would i be able to just go unplug it with the engine running when the time comes that it does it again? ( i went under there to do the tests on the wiring for the icp and had it unplugged and such. haven't had problem since, but thats not to say it wont come back either.
Old Jul 18, 2006 | 01:28 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
I would suggest drive with it plugged in when its fine, when the problem occures, pull over or whatever and then unplug it. Dont know if it'll do anything bad driving with it unplugged but you will know then and thier of a problem instead of waiting to see how it runs, tends to run fine and you replace the sensor just to have it act up at a later date since its an intermittant problem. be a waist of money
ENG661
Oct 27, 2011 06:16 PM
hornsurgeon
1997 - 2003 F150
Dec 19, 2010 12:17 AM
buckets
Oct 2, 2006 12:50 AM
Mel G
Jun 5, 2006 11:59 AM
bagman150
16
Mar 22, 2001 12:39 AM
