Code Question
Old Jul 14, 2006 | 10:57 AM
Deiselman's Avatar
Deiselman
Code Question
Can someone out there tell me what code P0231 means and possibly how to fix the problem? Dealer was no help.. Thanks...
Old Jul 14, 2006 | 11:53 AM
Pocket's Avatar
Pocket
P0231 - Fuel pump circuit failure - possible causes are fuse, relay, inertia switch, fuel pump, open/short circuit.
Old Jul 14, 2006 | 11:57 AM
lusher21's Avatar
lusher21
Howdy...Welcome to the best support group on the internet.
P0231-Fuel Pump secondary circuit low
At the top of the screen you will notice a banner that includes "Articles/Specs". For future reference, you will see articles there that define all the codes.
I'm a bit of a newby with this diesel business so I'll defer to the other experienced folks to help you with the causes/diagnosis of this code. Good luck.
Old Jul 14, 2006 | 02:40 PM
nodakford's Avatar
nodakford
l DTC P0231 indicates voltage was not present on fuel pump monitor circuit when the fuel pump was commanded on.
Possible causes:
-- open inertia switch
-- blown F/P fuse
-- open fuel pump monitor circuit
-- open fuel pump control circuit
-- faulty fuel pump relay
Old Jul 14, 2006 | 11:25 PM
Deiselman's Avatar
Deiselman
Question for Nodakford
Is it possible that the fuel pump on the frame rail may just be bad? I don't know if the relays and switches are a internal part of the pump or external somewhere on the truck. The truck runs and drives but will cut out from time to time and won't trigger the SES light when this stumble condition occurs. I have replaced the CPS but to no avail, the truck still runs like crap and will stall out from time to time and can be sometimes hard to start. Everytime I clear the code and recheck it once the truck acts up, I end up with the same code again, no others. I am new to this deisel thing, so excuse me if I sound a little dumbfounded. Thanks again!!
Old Jul 17, 2006 | 04:13 PM
strokd's Avatar
strokd
been there
Dieselman
i have a 99 F250 7.3 with banks powerpack and sixgun, i had the same problem i tried a million things and i got it down to two things 1. the wire harness that goes into the valve cover (driverside) was loose and the retainer clip was broke and 2 the ICP sensor wire plug one of the leads was expanded like were it got pried apart so i took a couple wire strands and tighted it up and have not had a problem sence. mine would stall and all of a sudden buck when ever it wanted.
KCMAGERS
May 8, 2007 12:36 AM
Quantrex
Sep 2, 2002 06:53 PM
May 3, 2002 01:31 AM
TallPaul
Nov 15, 2001 05:38 AM
jowilker
Jan 28, 2000 03:52 PM
