Bodywork to 68 Tailgate
Old Sep 24, 1999 | 11:38 PM
marketer's Avatar
marketer
My 9 month project is coming to a close. Lowering-done. P/S-done. P/B-done. 302 in-done. New brakes-done. P/S column-found.
Now that the truck is ready for the paint shop, I have small dent on the lower part of the tailgate, on the "ridge". I was wondering if a body shop could pull it out and bondo over it, or if I have to look for a straight tailgate.
Was also wondering about adding 3rd brake light instead of the handle, and relocate the handle inside the tailgate.
Thanks for any advise!
mark
Old Sep 25, 1999 | 07:16 AM
jowilker's Avatar
jowilker
Mark, why don't you run the tailgate by the paint shop and get his asvice, and he could help with the light as well.
John
Old Oct 15, 1999 | 08:36 AM
john's Avatar
john
Old Oct 29, 1999 | 01:43 AM
mike's Avatar
mike
>column-found.
>straight tailgate.
>mark
hey, i was needing advise on swapping manual for power. I have a 65 and believe the steering, brakes are the same. What did ya have to do for the brake and steering swap. and you mentioned finding a correct steering column, what was it and did ya have any wiring problems. as for your tailgate project, my dad has a body shop and you can fix the dent and put the brake light in the gate with no problem. please give me a hand on the power swap.
Old Oct 29, 1999 | 05:37 AM
jowilker's Avatar
jowilker
Mike BUY a donor from the mid 70s!!
You will need one with like engine and transmission, unless you swap the transmission too.
You can sell parts that you don't use and a salvage yard will come get the carcuss for the metal.
Harvest the I-beams, ps gear, pump, pullies, brackets, lines, clips, brake booster, M cylinder (for core), steering column.
When You have installed everything and it's working OK, get rid of the donor.
John
Old Oct 29, 1999 | 04:51 PM
Mark Rogers
Guest
Posts: n/a
I believe the 65 is in a different class, as the 67-72 is a seperate truck.
MPBrakes will sell you a set for ~$1000, which to me was better than having a doner truck, as everything is new. (My opinion)
Let me know if you have any other questions. Thanks for the tip on the tailgate-will look into it!
mark
Old Oct 29, 1999 | 05:50 PM
jowilker's Avatar
jowilker
Mark after you install the donor setup, install new rotors, wheel and master cylinders. Then you have new parts, that can be replaced from any parts house.
Most guys on this list don't have deep pockets like you must have.
John
Old Oct 31, 1999 | 12:07 AM
69man's Avatar
69man
here is an idea that i saw on this page.
<a href="http://www.wsu.edu/~moparman/tech/chmsl.html">http://www.wsu.edu/~moparman/tech/chmsl.html</a>
i hope it helps some.
Stevem4134
Jun 28, 2021 09:43 AM
1990ididually
Nov 12, 2013 07:06 PM
danorules
2004 - 2008 F150
Sep 4, 2013 02:10 PM
kdubinwa
Oct 12, 2010 10:54 PM
Bigredgashawg
Dec 15, 2003 01:22 PM
