Calibration number
Old 07-12-2006, 02:21 PM
machinist man's Avatar
machinist man
machinist man is offline
Calibration number
Where is the sticker with the calibration number for the PCM located? It's on the driver's side door jamb on my Ranger, but I looked there on my 02 F150 and all that's there is the VIN sticker. I also looked under the hood, and all I saw was the engine ID sticker on the driver's side valve cover. Anyone know?
Old 07-12-2006, 03:31 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It's not on the valve cover sticker?
Old 07-12-2006, 04:20 PM
xtrford's Avatar
xtrford
xtrford is offline
Your 02 will be on the passenger side door jam due to the fact your PCM is located under the kick panel on that side. I had the same problem when lookin for it also because my previous truck was a 95 which had the PCM under the drivers kick panel, hope this helps.
Old 07-12-2006, 05:49 PM
machinist man
LxMan,
The sticker on the valve cover is as follows:
2G876AA
(Bar code)
012400023
522 08-28-01 54L
I know the 8-28-01 is the build date and the 54L is the displacement, but I'm not sure what the other numbers are.
xtrford,
On the passenger side front pillar where the door hinges are, there is a sticker with a 4-digit number, it's WUQ3. Is that the calibration number?
Thanks to both of you for the response.
Old 07-12-2006, 08:59 PM
bear1's Avatar
bear1
bear1 is offline
yep thats it
Old 07-13-2006, 07:19 AM
machinist man
That answers my questions. Thank you.
bobv60
6.7L Power Stroke Diesel
10-29-2016 05:18 AM
joefj1200
33
03-17-2016 04:25 PM
jfirstford
06-06-2015 08:00 PM
TurboTuff
10-01-2010 07:58 AM
sparky
Bronco II
08-28-2003 10:47 AM
Quick Reply: Calibration number
