Sponsored by: Auxito
a/c trouble
Old Jul 18, 2006 | 09:01 AM
yellow_jacket's Avatar
yellow_jacket
Originally Posted by gtp20
Hello,
fficeffice" /><O></O>
I am looking for advice with my a/c before I have to take it to the garage. I have a 2001 F150, when I start the truck the a/c works just fine, once I start driving (highway speed) it cuts out and starts blowing hot air. If I shut it off for about 5 minutes and then turn it back on it will work fine for a bit maybe 10 minutes (all while at highway speed) then it starts to blow hot again. It seems to work fine most of the time driving around town at slow speeds. I was going to purchase an a/c sealer and repair kit and try that, I was hoping someone has experienced this problem before and could point me in the right direction.
<O></O>
Thanks
In addition to what projectSHO89 said, check the wiring to the a/c clutch. I have seen quite a few of the connectors go bad. Of course I have seen quite a few clutches go bad as well. First thing is to find out if the compressor is staying on when it blows hot air.
As far as the high side pressure switch goes. You shouldn't be running near it. It is there as a failsafe so that the system does not over pressurize and explode. It is a very scary thing to see that happen b/c the switch failed or someone disabled it. If there are no blockages in the system, the high side pressure will usually rise because of insufficient air flow through the condesor. This can be due to faulty fans, lots of bugs, or mud.
Old Jul 20, 2006 | 02:19 AM
ladiabla74's Avatar
ladiabla74
yellow_jacket
Will try but will be a while before I can check that. Thanks for the info.
Fordtraveler
Jun 2, 2010 03:59 PM
michaelgr
Bronco II
Jan 10, 2008 02:53 PM
Animalistic
Dec 19, 2007 08:31 PM
donoteat
Jan 17, 2007 01:31 AM
Dakrri
Feb 14, 2005 10:04 AM
