Gap
Old Jul 8, 2006 | 08:20 PM
out and about's Avatar
out and about
Gap
When installing new plugs is it always better to set to the lower recommended gap?
Old Jul 8, 2006 | 08:28 PM
jimdandy's Avatar
jimdandy
Smile
The wider the gap, the hotter the spark, but also more load on the system, but it won't matter as long as it is in the recommended range. When setting the gap, always use a wire guage, nothing flat such as a feeler gauge. jd
Old Jul 8, 2006 | 08:45 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
By setting to the mid/lower range of the gap, you will be within the recommended range of spec for a longer period than if you max it up front. Plug gap outside of the recommended range can cause, among other things, undesireable driveability issues.
Old Jul 9, 2006 | 08:16 AM
pawpaw's Avatar
pawpaw
As the spark gap is always increasing from wear, I choose to adjust the gap to the minimum side of spec, so it'll be in tolerance longer as Bill pointed out.
A gap on the narrow side of spec, will also help on really cold winter starts too.
Wider gaps begin to mess with engine timing & the spark can be blown out on really wide out of spec gaps, so the driveability thing Bill was referring to might come into play during stressful operating conditions.
Wider also works the system harder as Jim pointed out, so stay within spec & use a WIRE gauge as Jim suggested, to get the best accuracy on your gap.
Bend, don't bang the ground electrode, to adjust it's gap!!!!
topscrt
Modular V10 (6.8l)
Dec 14, 2013 01:37 PM
EXPLORER GUY
Dec 1, 2006 10:49 AM
traildawg
Jun 25, 2002 09:22 AM
Nitro
Mar 4, 2002 11:44 PM
beratte
1978 - 1996 Big Bronco
Feb 15, 2002 02:14 AM
