Modular V10 (6.8l)
need ring gaps for my v10
Old Dec 11, 2013 | 05:51 PM
topscrt's Avatar
topscrt
dont know where to find gap measurements
Old Dec 12, 2013 | 11:04 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
This probably going to turn out totally crappy, but buried in there is the top ring gap and intermediate ring gap.
Piston Ring Gap
Top - 0.13-0.28 mm
Intermediate - 0.25-0.40 mm
Full specs dump from my 2001 Truck service manual CD.
SPECIFICATIONS
General Specifications
ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿
³ Item ³ Specification ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÅÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ Displacement (CID) ³ 6.8L (415) ³
³ No. Cylinder ³ 10 ³
³ Bore/Stroke ³ 90.215/105.8 mm ³
³ Fire Order ³ 1-6-5-10-2-7-3-8-4-9 ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ Cylinder Head/Valve Train ³
ÃÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÂÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄ´
³ Combustion Chamber Volume ³ 52.6 - 51.6 cc ³
³ Valve Seat Width Ä Intake ³ 2.1-1.9 mm ³
³ Valve Seat Width Ä Exhaust ³ 2.1-1.9 mm ³
³ Valve Seat Angle ³ 45.00-44.50 degrees ³
³ Valve Seat Runout (T.I.R.) ³ 0.025 mm ³
³ Valve Arrangement (Front to Rear) ³
³ Valve Stem Guide Clearance ³ ³
³ Intake ³ 0.069-0.020 mm ³
³ Exhaust ³ 0.095-0.045 mm ³
³ Valve Head Diameter ³ ³
³ Intake ³ 44.63-44.37 mm ³
³ Exhaust ³ 34.12-33.88 mm ³
³ Valve Face Runout (Limit) ³ 0.05 mm ³
³ Valve Face Angle ³ 45.75-45.25 degrees ³
³ Valve Stem Diameter ³ ³
³ Intake ³ 6.995-6.975 mm ³
³ Exhaust ³ 6.970-6.949 mm ³
³ Valve Stem Diameter (List ³ ³
³ Oversizes) ³ ³
³ Intake ³ N/A ³
³ Exhaust ³ N/A ³
³ Valve Spring Compression ³ ³
³ Pressure ³ ³
³ Intake (N @ Spec. ³ 667.3 N @ 28.02 mm ³
³ Length) ³ ³
³ Exhaust (N @ Spec. ³ 667.3 N @ 28.02 mm ³
³ Length) ³ ³
³ Valve Spring Free Length ³ ³
³ Intake ³ 50.2 mm ³
³ Exhaust ³ 50.2 mm ³
³ Valve Spring Installed ³ ³
³ Pressure N @ Spec. Length ³ ³
³ Intake ³ 289.1 N @ 40.01 mm ³
³ Exhaust ³ 289.1 N @ 40.01 mm ³
³ Valve Springs Installed ³ ³
³ Pressure N @ Spec. Length Ä ³ ³
³ Service Limit ³ ³
³ Intake ³ 274.6 mm @ 40.01 mm ³
³ Exhaust ³ 274.6 mm @ 40.01 mm ³
³ Valve Springs Ä Out of Square ³ ³
³ Limit ³ ³
³ Intake ³ 2.5 degrees ³
³ Exhaust ³ 2.5 degrees ³
³ Valve Guide Inside Diameter ³ 7.044-7.015 mm ³
³ Camshaft ³
³ Lobe Lift ³ ³
³ Intake ³ 6.58077 mm ³
³ Exhaust ³ 6.58551 mm ³
³ Lobe Lift Ä Allowable Lift ³ 0 ³
³ Loss ³ ³
³ Valve Lift @ Zero Lash ³ ³
³ Intake ³ 12.00 mm ³
³ Exhaust ³ 12.00 mm ³
³ Camshaft End Play ³ 0.25-0.188 mm ³
³ End Play Service Limit ³ 0.025-0.188 mm ³
³ Journal to Bearing Clearance ³ 0.076-0.025 mm ³
³ Clearance Service Limit ³ ³
³ Journal Diameters ³ 26.962-26.936 mm ³
³ Journal Inside Diameter (Cap ³ 27.012-26.987 mm ³
³ Assembled) ³ ³
³ Camshaft Runout: Full ³ 0.09 mm (5 Places) ³
³ Indicator Measurement on all ³ ³
³ journals when supported on ³ ³
³ front and rear journals. ³ ³
³ Cylinder Bore Diameter ³ ³
³ Grade 1 ³ 90.200-90.210 mm ³
³ Grade 2 ³ 90.210-90.220 mm ³
³ Grade 3 ³ 90.220-90.230 mm ³
³ Piston ³
³ Piston Diameter (Grade 2) at ³ 90.180 ñ 0.005 mm ³
³ Right Angle to Pin Bore ³ ³
³ Piston to Bore Clearance ³ (-0.005) to +0.025 mm ³
³ Pin Bore Diameter (Piston) ³ 22.008-22.014 mm ³
³ Pin Diameter ³ 22.0005-22.0030 mm ³
³ Clearance (Neg. or Pos.) ³ 0.01395-0.005 mm ³
³ Pin Bore Diameter (Rod) ³ 22.012-22.024 mm ³
³ Clearance ³ 0.009-0.0235 mm ³
³ Ring Groove Width ³ ³
³ Top ³ 1.503-1.505 mm ³
³ Intermediate ³ 1.502-1.504 mm ³
³ Oil Control ³ 3.030-3.050 mm ³
³ Piston Ring Gap ³ ³
³ Top ³ 0.13-0.28 mm ³
³ Intermediate ³ 0.25-0.40 mm ³
³ Oil Control ³ 0.15-0.65 mm ³
³ Crankshaft ³
³ Main Bearing Journal Diameter ³ 67.482-67.504 ³
³ Maximum Out-of-Round ³ 0.0075 mm Between Cross ³
³ ³ Sections ³
³ Maximum Taper ³ 0.004 mm ³
³ (Straightness) ³ ³
³ Runout: FIM of center ³ 0.05 mm 3 Places ³
³ journals when located on ³ ³
³ front and rear journal ³ ³
³ Clearance Ä Crankshaft ³ 0.048-0.024 mm ³
³ Journal to Main Bearing ³ ³
³ Clearance ³ ³
³ Connecting Rod Journal ³ 53.003-52.983 mm ³
³ Diameter ³ ³
³ ³ Sections ³
³ Crankshaft End Play ³ 0.075-0.377 ³
³ Connecting Rod ³
³ Big End Journal Inside ³ 53.049-53.027 mm ³
³ Diameter with Assembled ³ ³
³ Liners ³ ³
³ Rod Bearing to Journal ³ 0.064-0.026 mm ³
³ Clearance ³ ³
³ Pin Bore Diameter (Rod) ³ 22.024-22.012 mm ³
³ Balance Shaft System ³
³ Balance Shaft Journal ³ 26.962 - 26.936 mm ³
³ Diameter ³ ³
³ Clearance Ä Balance Shaft ³ 0.076 - 0.025 mm ³
³ Journal to Cylinder Head ³ ³
³ Cylinder Head B/S Journal ³ 27.012 - 26.987 mm ³
³ Diameter ³ ³
³ Gear Backlash ³ 0.0076 - 0.1295 mm ³
³ Balance Shaft Endplay ³ 0.04 - 0.18 mm ³
³ Rod Length (Centerline Bore ³ 169.1 mm ³
³ -to-Bore) ³ ³
³ Alignment ³ ³
³ Bore-to-Bore Max. Twist ³ ñ 0.05 mm ³
³ Bore-to-Bore Max. Bend ³ ñ 0.038 mm ³
³ Side Play (As Assembled to ³ ³
³ Crank) ³ ³
³ Standard Play ³ 0.410 ñ 0.26 mm ³
³ Max Play ³ 0.670 mm ³
³ Sealant and Lubricants ³
³ Silicone Gasket and Sealant ³ WSE-M4G323-A4 ³
³ F7AZ-19554-EA ³ ³
³ Premium Engine Coolant E2FZ ³ ESE-M97B44-A ³
³ -19549-AA ³ ³
³ (in Oregon, F5FZ-19549-CC; in ³ ³
³ Canada, CXC-10) ³ ³
³ Super Premium SAE 5W-20 ³ WSS-M2C153-H ³
³ Engine Oil ³ ³
³ XO-5W20-QSP ³ ³
³ Metal Surface Cleaner ³ WSE-M5B392-A ³
³ F4AZ-19A536-RA ³ ³
ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÁÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ
Old Dec 14, 2013 | 10:29 AM
topscrt's Avatar
topscrt
thank you very much
Old Dec 14, 2013 | 01:37 PM
krewat's Avatar
krewat
Originally Posted by topscrt
thank you very much
No problem
460Powered
Nov 10, 2010 06:06 AM
jdasilva644
Oct 15, 2010 11:13 PM
55 f350
Jun 9, 2007 03:26 AM
BBF250
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 9, 2007 02:35 PM
e william
Jun 17, 2003 07:07 AM
