460 retarded cam timing
Thanks,
Picklebill
Yes it will make a difference in your perormance.
I recently did this to my `85 460. I used a pre-emissions (pre 1972) stock timing gears and chain (only one key way). From Summit the set was around $25. The gears can be bought separately, but you will spend more then $25 doing it that way and a new chain never hurts.
To get the new set lined up right you will need to rotate the cam a small amount. First line up the old set to the marks on the two gears (making sure you are on TDC for number one and not number six cylinder). Remove the old gears and chain and then slide the new gears on without the chain. You will see that the cam will need to be rotated just a bit to bring the alignment marks together. Carefully rotate the cam and then slide the new gears off, put the chain on the gears, and slide them back on. After you have it all back together make sure you reset your ignition timing because it will now be advanced also. Note: the distributor does not need to be removed for this job.
You will not see a huge difference in performance. I noticed a better idle and a little more grunt in the lower rpm range. Good luck and feel free to ask any questions.
Mark
Also, I have come across a stubborn woodruff key on the crank... What can someone recommend to get it outta there without damage to it or the crank snout?
Mark
Mark [/B]
Spray a little penetrating oil on it, use a small pointed punch, and with a small hammer just try to tap the punch under the edge of the woodruff key, it should pop up out of there. If you take it easy you won't hurt anything. Of course don't put the punch anywhere but in the key way.
The motor is put at TDC on the number one cylinder. The position of the crank and the pistons does not change, but rather, the relative position of the cam is advanced or retarded while the crank stays put. When going to the pre-emissions cam setting you are effectively advancing the cam 4 degrees from the previous stock position in which it was timed. Thus, that is why the cam is rotated slightly.
While you are correct that there are three position crank gears - after market gears that provide user flexibility - each key way represents only a reference point. When the crank gear is slid on in any one of the three positions it will always have a mark - there are three of those too - that is at the top of the crank gear. In order to get the cam gear mark to line up with the crank gear the cam will need to be rotated slightly one way or another depending if you are advancing or retarding from the previous position.
And, as a side point, the cam in a motor that has a lot of chain stretch will be even further retarded and simply replacing the chain will require some rotation to get the cam back to the stock position. Based on the stretch in my chain I guessed that my cam was about 8 degrees retarded, 4 degrees from the factory and another 4 degrees from chain stretch.
Hope that clarifies it, but if not, just ask.
Mark
Idunno... Maybe I am not getting my point across???
I have two vehicles to do this on, so I was just looking at different ways... Isn't it easier to turn the crank by putting a socket on the bolt, than it is to turn the cam, what with all the valve spring pressures on it and all?
Mark
Yes, in theory, the crank could go ccw. But, when you do that, you lose the benefit of having the mark on the crank gear in place (straight up) to align the cam gear (which has a mark that will be straight down) so you would end up having to guess if they were in fact aligned.
It was rather easy to rotate the cam. After putting the new cam gear on I simply ran the cam front bolt in by hand and using a long wrench to control the movement rotated it clockwise so that it aligned with the mark on the crank. It did not have to go very far. This tightened the bolt a bit so when I needed to remove it, and did not want the cam to rotate back, I did so by putting gentle increasing pressure only sufficient to slowly start the bolt lose, but not so much pressure so as to cause the cam to rotate back. Plus, no jerking movement. If the cam had started to rotate I’m sure that holding the cam gear would have kept it in place.
Good luck,
Mark
Interesting information you have on the early and late part numbers for performance timing sets. You have got me curious now. When I got the Comp Cams double roller set for my 460, there were late and early part numbers also. I got the late since my engine was a 79. I just figured it was a production fit up thing.
Did not even think of this.
Sheesh, I guess the only way to solve this is to have the late set and early set beside eachother, put both keyways straight up at the zero, and see if it lands on the same tooth or not???
I want my mommy!!!
Mark
