Cam question
Old Jul 8, 2006 | 12:34 PM
sneak's Avatar
sneak
Cam question
I have a 76 250 2wd with a 390. (4 barrel holley, stock) I have to be honest, I drive it like I stole it, and it just loves the attention. I rev it high, and I enjoy the very even torque curve, but it has a 4 spd with granny and 3.73 rear gears. I want to get a new cam with gobs of top end power, but I don't want to have horrible flat spots in my acceleration. It's been a while since I looked at cams, so could domeone help me out, what am I looking for?
Old Jul 8, 2006 | 12:49 PM
4starcstms's Avatar
4starcstms
Heres the Cam im going with, Ive driven another truck with a similar cam and loved it, felt great, sounded awesome, Lopey Idle
http://store.summitracing.com/partde...5&autoview=sku
Basic Operating RPM Range: 1,800-6,000 RPM
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 236
Duration at 050 inch Lift: 230 int./236 exh.
Advertised Intake Duration: 274
Advertised Exhaust Duration: 286
Advertised Duration: 274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.562 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.565 in.
Valve Lift with Factory Rocker Arm Ratio: 0.562 int./0.565 exh. lift
Lobe Separation (degrees): 110
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: FB XE274H-10
Quantity: Sold individually.
Notes: Will not fit factory Ford FE solid lifter engine blocks.
You might wanna call comp cams, or crane, or whoever your fav. cam maker is and talk to em about your engine specifics, what you want out of it. nobody knows their cams like they do..
Old Jul 8, 2006 | 01:01 PM
sneak's Avatar
sneak
Allright, Thanks.
Old Jul 11, 2006 | 01:54 PM
sutphen77's Avatar
sutphen77
I bought this one, I will let you know how it works..
<TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Brand:</TD><TD class=overview-c2 width="75%">Isky Racing Cams</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Product Line:</TD><TD class=overview-c2 width="75%">Isky Solid Flat Tappet Camshafts</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Cam Style:</TD><TD class=overview-c2 width="75%">Mechanical flat tappet</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Basic Operating RPM Range:</TD><TD class=overview-c2 width="75%">4,000-7,000 RPM</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Intake Duration at 050 inch Lift:</TD><TD class=overview-c2 width="75%">266</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Exhaust Duration at 050 inch Lift:</TD><TD class=overview-c2 width="75%">266</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Duration at 050 inch Lift:</TD><TD class=overview-c2 width="75%">266 int./266 exh.</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Advertised Intake Duration:</TD><TD class=overview-c2 width="75%">320</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Advertised Exhaust Duration:</TD><TD class=overview-c2 width="75%">320</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Advertised Duration:</TD><TD class=overview-c2 width="75%">320 int./320 exh.</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Intake Valve Lift with Factory Rocker Arm Ratio:</TD><TD class=overview-c2 width="75%">0.596 in.</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Exhaust Valve Lift with Factory Rocker Arm Ratio:</TD><TD class=overview-c2 width="75%">0.596 in.</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Valve Lift with Factory Rocker Arm Ratio:</TD><TD class=overview-c2 width="75%">0.596 int./0.596 exh. lift</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Lobe Separation (degrees):</TD><TD class=overview-c2 width="75%">108</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Intake Valve Lash:</TD><TD class=overview-c2 width="75%">0.026 in.</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Exhaust Valve Lash:</TD><TD class=overview-c2 width="75%">0.026 in.</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Computer Controlled Compatible:</TD><TD class=overview-c2 width="75%">No</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #f5f5f5" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Grind Number:</TD><TD class=overview-c2 width="75%">EE-393</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD class=overview-c1 width="25%">Quantity:</TD><TD class=overview-c2 width="75%">Sold individually.</TD></TR></TBODY></TABLE>
Old Jul 11, 2006 | 08:59 PM
390fe's Avatar
390fe
sutphen77, what are you going to run that motor in?
Old Jul 12, 2006 | 12:24 PM
sutphen77's Avatar
sutphen77
94 Mustang
Old Jul 13, 2006 | 10:56 AM
Mike G's Avatar
Mike G
Sneak - what are your intentions with the rest of the motor, or are you just looking to drop in a cam? The 76 truck 390 was relatively low on compression, you will kill the motor with any of these grinds.... We need to know what the plan is to recommend anything remotely correct.
--Mike
Old Jul 13, 2006 | 12:25 PM
sneak's Avatar
sneak
Well, I would like to end up with a clark 280 series five speed, put tri-y headers on it, true duel, and maybe a Holley 750, but all this would happen over maybe two or three years. It only has 103k miles on it, original. I know that the correct cam could really wake this engine up, and that one not too far off could really kill it.
I was thinking at the biggest, something like this This.
<table border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Brand:</td><td class="overview-c2" width="75%">COMP Cams</td></tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Product Line:</td><td class="overview-c2" width="75%">COMP Cams Xtreme Energy Cam and Lifter Kits</td></tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Cam Style:</td> <td class="overview-c2" width="75%">Hydraulic flat tappet</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Basic Operating RPM Range:</td> <td class="overview-c2" width="75%">1,300-5,600 RPM</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Intake Duration at 050 inch Lift:</td> <td class="overview-c2" width="75%">218</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Exhaust Duration at 050 inch Lift:</td> <td class="overview-c2" width="75%">224</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Duration at 050 inch Lift:</td> <td class="overview-c2" width="75%">218 int./224 exh.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Advertised Intake Duration:</td> <td class="overview-c2" width="75%">262</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Advertised Exhaust Duration:</td> <td class="overview-c2" width="75%">270</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Advertised Duration:</td> <td class="overview-c2" width="75%">262 int./270 exh.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Intake Valve Lift with Factory Rocker Arm Ratio:</td> <td class="overview-c2" width="75%">0.513 in.</td> </tr> <tr style="background-color: rgb(255, 255, 255);" onmouseover="this.style.backgroundColor='#f5f5f5'; " onmouseout="this.style.backgroundColor='#FFFFFF'"> <td class="overview-c1" width="25%">Exhaust Valve Lift with Factory Rocker Arm Ratio:</td> <td class="overview-c2" width="75%">0.520 in.</td></tr></tbody></table>
Edit: I need to put a tach in it to see what my operating rpm's are.
Old Jul 13, 2006 | 12:33 PM
sneak's Avatar
sneak
Or maybe THIS.
Edit: Also, does anyone have the specs for the stock cam that came in this engine?
Old Jul 13, 2006 | 07:44 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Comp cams 262/270 looks the best so far, do a dyno sim check to see if you can advance it 2-3 degrees. You need to know what compression ratio zone that can works best in and yours.
.....=o&o>.....
furrby
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 13, 2015 10:13 AM
ptboi94
May 19, 2011 09:20 PM
oricle
Nov 25, 2004 12:34 AM
fordman428
Dec 5, 2003 03:51 PM
cjcathey2002
Aug 13, 2002 09:02 PM
