Cams
Old Nov 22, 2004 | 10:24 PM
oricle's Avatar
oricle
Cams
Well im looking at camming my 460. I currently have L&L Headers, along with a gibson exhaust. I was searching around for cams and am curious as to quiet what duration, lift, and lobe sloap affect it? What are some good performance cams? I have a 91 F250, and want to use it basiclly want power for the street.
Old Nov 22, 2004 | 10:28 PM
oricle's Avatar
oricle
BTW: what are the estimated HP and Toruqe specs im looking at with a performance cam L&L Headers and a Gibson exhaust?
Old Nov 23, 2004 | 06:30 AM
jwtaylor's Avatar
jwtaylor
The quickest answer, contact crane or comp cams, they'll fix you up, their websites have contact information and tech lines, just for cam questions.
Good luck
Old Nov 23, 2004 | 01:40 PM
fordeverpower's Avatar
fordeverpower
Duration is how long the valves stay open in crankshaft degrees. More duration helps build horsepower but moves the power ranges up in rpm. LIft is the valves lift and more lift is more power. Lobe seperation is the amount of degrees betweem max lift of the exhaust and intake lobes. More lobe seperation reduces overlap and has more engine vaccum. For a street cam something like 112 is ideal. HIgh performance cams have a 106 or 108 lobe seperation. And overlap is when both valves are open at the same time. But the best thing for most people to do is call crane or comp and have them pick you a cam. I like to pick my own.
Old Nov 24, 2004 | 04:26 AM
mako5972's Avatar
mako5972
Comp Cams offers a computer controlled cam for speed density, and it works with the stock computer, it is a hydraulic flat tappet cam. The operating range is 1000 to 5200 rpm's. The camshaft part number is 34-255-5. The camshaft grind number is XE256H-14. The duration @ .050 Intake 212, Exhaust 219. The valve lift with 1.73 rockers Intake .490, Exhaust .495. The lobe separation is 114 degrees. The phone number is 1-800-999-0853, the website address is www.compcams.com.
Old Nov 25, 2004 | 12:34 AM
deerhunter3814's Avatar
deerhunter3814
Wink
JWTAYLOR gave you the best advice, you can get many different opinions but the mfg. of cams know what you need.
Make a phone call.
Comp cams 1-800-999-0853
Crane cams 1-386-258-6174
furrby
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 13, 2015 10:13 AM
ENCSDEI
Apr 25, 2007 09:16 PM
keyul
Modular V8 (4.6L, 5.4L)
Aug 17, 2006 03:47 PM
fordman428
Dec 5, 2003 03:51 PM
mobilmike
Feb 3, 2003 06:19 AM
