Sponsored by: Real Truck
Help with wheel backspacing?
Old Jul 8, 2006 | 06:30 AM
CobraGT40's Avatar
CobraGT40
Question Help with wheel backspacing?
I've decided which wheels to go with and will order them when I pick up my lift kit Monday...I'm going with the American Eagle series 101 16X10's, and then using my current 315/75/16 BFG Radial All Terrains...My only question is "what backspacing should I use?" I don't want them sticking too far out of the wheel-wells, but I also don't want them rubbing on my front leaf springs...Any Ideas? Or better yet, if anyone has any pics of examples?
Thanks ! ! !
Scott
Old Jul 8, 2006 | 09:57 AM
pbr man's Avatar
pbr man
I have American Eagle 184 16x8 with 4.5'' backspace. With the 315's they don't stick out past the wheel wells and no rubbing on the inside except occassionally on the plastic fender liner.
Old Jul 8, 2006 | 10:15 AM
Betaracer's Avatar
Betaracer
If you have a 2005 and newer truck, use 5.5" back spacing. If you have a 2004 and older, use 4.5".
Old Jul 8, 2006 | 04:18 PM
BFR250SD's Avatar
BFR250SD
for a 99-04 truck, use 4 1/4 - 4 5/8 backspacing and you'll be fine as far as inside rubbing.
Outside rubbing is gonna vary, depending on wheel width. If you are sticking with an 8 - 10" wheel width, you'll be G2G!
acw592
Jan 29, 2009 02:30 PM
Trey
Apr 12, 2006 12:53 PM
Vin-Man
Dec 5, 2004 10:43 AM
04SilverSCFX4
2004 - 2008 F150
Oct 28, 2004 11:30 PM
