Transmission will not downshift
Old Jul 6, 2006 | 04:38 PM
vip09's Avatar
vip09
I have a 1997 Ford F-350 with auto transmission. When I stop the truck, the transmission will not downshift. I can pull lever down to 1 position and it will shift to first gear, and will shift up from there on. I have to pull lever down to 1 ever time I stop for transmission to downshift. Any ideas what is causing this problem?
Old Jul 7, 2006 | 07:04 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jul 8, 2006 | 07:14 AM
Cuda_jim's Avatar
Cuda_jim
Try removing and reinstalling all of the electrical connections on the trans. Maybe a lose or bad connection, especially the TRS Trans Range Selector. Its on the driver side of the tranny. The shift cable is attached to it.
How long has it been since a tranny fluid and filter change?
Old Jul 8, 2006 | 08:44 AM
Kwikkordead's Avatar
Kwikkordead
Have you checked the VSS sender on the rear axle?
Homerunking2394
Nov 9, 2015 01:57 PM
Heavy Duty f250
May 30, 2011 11:09 AM
epos48
Jun 3, 2007 06:55 PM
storeboy98
1983 - 2012 Ranger & B-Series
Nov 27, 2003 12:28 AM
