Sponsored by: Real Truck
door ajar dash
Old Jul 6, 2006 | 02:01 PM
Blckf350's Avatar
Blckf350
Question door ajar dash
in my 1999 f350 regular cab the dashboard light saying door ajar is always on even when both doors are completely closed, this then keeps the cargo light on and now when i drive the battery light in dash is on? what do i do?
Old Jul 6, 2006 | 02:09 PM
zx250's Avatar
zx250
Of the next Riffraff East
Welcome to FTE and welcome to a very common problem with our trucks and Fords in general. It is usually fixed by spraying WD-40 on the door latch. Spray all moving parts of latch and work the door several times. Did mine 2yrs ago and have not had a problem since. Spray into the door latch as best you can. Good luck and welcome.
Old Jul 6, 2006 | 02:10 PM
zx250's Avatar
zx250
Just seen the rest of you post about the battery light. This usually means you have a bad battery or more likely an alt. going out.
Old Dec 25, 2006 | 07:38 PM
savage2211's Avatar
savage2211
Hi I had the same problem,and used wd40 in the door latch... Works great now!!!
Old Dec 25, 2006 | 09:54 PM
DD1684's Avatar
DD1684
Seems to be a common ailment on the SD trucks, although mine doesn't do it .
Old Dec 25, 2006 | 10:14 PM
Fomoko1's Avatar
Fomoko1
Same deal on my 98 Ranger supercab, all the doors are closed tight and the dash light is on. I`ll try the WD 40 soon, this is too much of an annoyance and at times the buzzer chimes in as well. Another problem is the interior light thinks it should stay on.
Old Dec 26, 2006 | 09:25 AM
DetailerDave's Avatar
DetailerDave
Mine did the same thing. Interior light kept going on and off, too. Drove me nuts! Opened the door, sprayed some WD40 in where the door latch mechanism is, opened and closed door a few times, and so far, so good.
Old Dec 26, 2006 | 01:35 PM
Blckf350's Avatar
Blckf350
i figured out that it only doesnt shut off if i iniate it myself by unlucking the passenger side door using the key from the outside and if i do that i have to shut it off by first turning the key just so the gauges jump, then lock the passenger side door, open the door from the inside and shut it.. works everytime and now i dont unluck it with the key
Blckf350's Avatar
Blckf350
i hope that makes sense
Old Dec 26, 2006 | 08:35 PM
jake00's Avatar
jake00
I used electrical contact cleaner, Seems to work longer than wd for me
dirgio
Jan 26, 2011 05:19 PM
2002 X
May 27, 2009 07:48 PM
bager
1997 - 2003 F150
Mar 17, 2004 06:55 PM
Cheetah Daddy
Feb 11, 2003 09:39 AM
SWGROUP
1997 - 2003 F150
Feb 9, 2003 05:55 PM
