Sponsored by: Auxito
door ajar light
Old Feb 4, 2004 | 07:09 PM
bager's Avatar
bager
door ajar light
I have a 98 f 250 and the door ajar light doesnt go off when it should. any suggestions would be nice
Old Feb 4, 2004 | 07:11 PM
bobs75f-250's Avatar
bobs75f-250
spray wd-40 in the latches and jiggle them around with a screwdriver or something, it works for me.
Old Feb 4, 2004 | 07:12 PM
couleeman's Avatar
couleeman
Close the door. Just kidding
Somebody will help you here soon, I am not much help.
Old Feb 4, 2004 | 07:13 PM
bager's Avatar
bager
thanks
Old Feb 7, 2004 | 03:46 PM
m1freak's Avatar
m1freak
Bager
You have to go to Ford and get a new switch its located inside the door below the door lacth mech. It's a chore replacing it. Its like a 10 dollar part.
Old Feb 7, 2004 | 04:56 PM
PaulC's Avatar
PaulC
The WD-40 tip is a good start. Instead of working the switches with a screwdriver, just open and close the door several times.
Old Feb 8, 2004 | 09:31 AM
a500ponies's Avatar
a500ponies
door
hey before you change that switch make sure you dont try to pry the door panel off .they dont pop off like the old trucks and you will end up braking the panel ..the clips cant be replaced . so be warned the dealer just did this to my truck . they broke the panel and had to order me a new one ...
Old Mar 9, 2004 | 07:34 PM
VTXTC's Avatar
VTXTC
Talking lube trick worked like a charm
I'd been having problems with my dome light not turning off for 10 minutes for the last year or so, and the doors not autolocking. I sprayed all the door latches with a liberal coating of chain wax. It stays put better than WD-40, I have the 3 door truck, so I also hit both latches on the rear door, and the tailgate and hood latches while I was at it.
Everything works smoother now, and the dome light goes off when I shut the door!!
Definitely try this fix before going through the hassle of replacing a switch that may not be bad.
Old Mar 10, 2004 | 01:50 PM
d0n_3d's Avatar
d0n_3d
i had the same annoying problem...soaked both latches with wd-40 and i haven't had a problem since...
Old Mar 10, 2004 | 09:57 PM
krunker's Avatar
krunker
I'd avoid the chain oil in that it will cause dirt to build up on it.
Old Mar 10, 2004 | 10:16 PM
AegisSailor's Avatar
AegisSailor
WD-40 is a tried and true solution. This is a VERY common problem(Check the FAQ), and everytime somebody asks about it, they get the same answer from everybody. I've rarely seen anybody come back and say it didn't work.
Old Mar 11, 2004 | 04:25 AM
archer1's Avatar
archer1
Wd is a solvent and dissapates over time, it just cleans the switch and allows it to work properly with a little lub in it.
Old Mar 17, 2004 | 06:55 PM
jkromm's Avatar
jkromm
my latches kept gumming up even with wd40, I had to get new switches
sbappleg8
1983 - 2012 Ranger & B-Series
15
Aug 2, 2017 11:45 AM
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
joannematta
Oct 17, 2011 03:02 PM
socalarcade
Dec 12, 2010 05:17 PM
TampaDave
May 5, 2010 05:04 AM
