Sponsored by: Innova
Glass box
Old Jul 7, 2006 | 01:17 PM
Mofo dude's Avatar
Mofo dude
So I should put 2 hole in each side of the box for the ports right, that will work?
Old Jul 7, 2006 | 01:28 PM
FTE Trigger's Avatar
FTE Trigger
Originally Posted by 99Trigger3_0
...And its calling out port specs. 3" Dia. by 6.75" long. (simply put)
2-ports per woofer.
2- per woofer / chamber
Yeap!
Mofo dude's Avatar
Mofo dude
I just talked to my dad and he said that he was going to put like a chrome railing insted of the L brackets and silicone it up would this work? Since it is goin to be ported does it have 2 be air tight around the seams and stuff?? I was also wondering how would we get the wires from the amps 2 the subs and make them air tight?
Old Jul 7, 2006 | 01:39 PM
FTE Trigger
i'd still seal the seams... Jus' wouldn't go nuts with the sealant material.
For getting your wires from point A...into point B (the box) i'd use these.
Commonly referred to as speaker termination cups.
Old Jul 7, 2006 | 01:43 PM
FTE Trigger
You would probably be using the larger gauge speaker wire.
So you may want to find some that accept those larger cables or even banana plugs.
Old Jul 7, 2006 | 01:44 PM
Mofo dude's Avatar
Mofo dude
Do you think chrome rail and slilcone will hold the box from falling apart from these monster speakers?
Old Jul 8, 2006 | 12:05 AM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
Well, if you're making the box purely out of glass, probably not. If you're framing it out with a nice wood, then yeah.
Ryan
Old Jul 8, 2006 | 12:09 AM
FTE Trigger
he's referring Lexan as to being "Glass"
Old Jul 9, 2006 | 09:46 PM
Mofo dude's Avatar
Mofo dude
I already said that I WAS NOT using glass I was using Lexan
crazyone77
Modular V10 (6.8l)
13
Aug 29, 2022 04:41 AM
Scndsin
Mississippi Chapter
152
Nov 1, 2012 05:15 AM
wasowski
Jan 21, 2011 07:04 PM
herbs
Jun 30, 2010 12:19 AM
