Where is the oil pressure sender on V10 Van? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V10 (6.8l)
Reload this Page >
Modular V10 (6.8l)
Old 10-10-2010, 04:49 PM
crazyone77
crazyone77 is offline
crazyone77 is starting off with a positive reputation.
Hey all, I have a 2002 E450 V10 Van, trying to install a real oil pressure gauge. Where the hell is that ****???
Thanks
Brandon
Old 10-10-2010, 05:10 PM
Mr-Pipeline's Avatar
Mr-Pipeline
Mr-Pipeline is offline
Mr-Pipeline has a good reputation on FTE.Mr-Pipeline has a good reputation on FTE.
Here's a picture of a 2006 E-series van. I believe all V-10 are located in the same location, it's just infront of the motor mount. I removed the sending unit and installed a tee. I installed the sending unit into one side and the connection for may mechanical gauge into the other, works great. You should be able to see it on the drivers side front of the engine. Hope this helps.
Old 10-10-2010, 05:39 PM
crazyone77
Doh, I didn't look too hard, found it, Oil pressure gauge installed
Thanks
Now if only you had any easy fix for some heads
B
Old 02-14-2011, 04:49 PM
mwsF250
mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
Hey guys, do you recall what the thread size was?
I'm guessing 1/4 NPT?
Old 03-27-2016, 04:53 AM
FORDMAN4LIFE12
FORDMAN4LIFE12 is offline
FORDMAN4LIFE12 is starting off with a positive reputation.
I have a bit of oil dripping from my oil pressure sender pictured above with the connection attached. My question is how can I replace that gasket?????????
Old 03-31-2016, 11:30 PM
dkf's Avatar
dkf
dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
I have had a sender on another vehicle leak out the end where the connector is before. I had to replace the sending unit to fix it.
Old 12-26-2017, 10:09 PM
Dasteufelhund
Dasteufelhund is offline
Dasteufelhund is starting off with a positive reputation.
Oil Sending location
Would you please be so kind as to circle this because I don't know where/what I'm looking at here....
Thank you,
P
Old 12-27-2017, 06:47 PM
Hogtrapper's Avatar
Hogtrapper
Hogtrapper is offline
Hogtrapper is starting off with a positive reputation.
I honestly don't know but maybe, just maybe it's in the area painted blue?
Old 12-28-2017, 03:59 PM
Dasteufelhund
Duh! Thanks looks like it'll be easier to get to that thang from the front. How much oil loss once that is out?
Old 12-28-2017, 05:37 PM
Sam I Am's Avatar
Sam I Am
Sam I Am is offline
Sam I Am has a good reputation on FTE.Sam I Am has a good reputation on FTE.
Thank you,
P
van V10 oil sender location
The blue area appears to be a replaced freeze plug.
Removal of the oil pressure sensor is not going to drain out all of the oil as long as the engine is not running and the vehicle is not dangling suspended with the front end pointed downward. Some will drip out if the engine is not running, and it may be messy, but it will be an inconsequential amount.
If the engine is not running.
Old 12-29-2017, 01:10 PM
Dasteufelhund
That is awesome!! Thank you!!!
P
Old 12-30-2017, 11:48 PM
Deagle12
Deagle12 is offline
Deagle12 is gaining momentum as a positive member of FTE.
I just replaced mine. It kind of surprised me how much oil came out. When I replaced the oil pressure switch on a trailblazer not very much came out at all. Luckily with this, I had the replacement in hand and got the new one in quickly. Lost about 1/8 quart I'd say. What's great about these compared to the GM one is that you don't need a special socket to get it out. Since the electrical connector is smaller than the actual bolt, you can just use a regular 21mm wrench. A 21mm deep socket will fit on the switch, but I couldn't actually get a wrench into the cramped space, so I just went with an open ended wrench.
Gene W
08-21-2017 04:20 PM
annaleigh
07-23-2017 06:57 AM
budman325
2009 - 2014 F150
07-11-2017 07:37 AM
jhaerle
02-06-2017 11:58 AM
Club Wagon
Large Truck
55
03-05-2016 12:37 PM
Quick Reply: Where is the oil pressure sender on V10 Van?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
