Valve Cover replacement questions
Old Sep 17, 2009 | 06:55 PM
dpellicone's Avatar
dpellicone
I have finally broke down and started replacing my valve cover gaskets on my 85 5.0 FI. I have run into some questions. I am having a problem getting the passenger side cover off. I do not want to hit or bend it too much. Also can someone recommend a good way to remove the gasket material that will not come off? is there a gasket removal product? Last question, it has been at least 20 years since I have done this. Is gasket sealer still needed with these new rubber gaskets? if so where do you put the sealer?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Thanks in advance
Nick
<o></o>
Old Sep 17, 2009 | 07:27 PM
Swatter's Avatar
Swatter
I would try to use the rubber gasket only, reason being my old gasket melted and drained down into 2 of the push rod
holes and turn into something like hard black concrete. I had to remove the push rods and chisel it out while running
a shopvac to keep it from falling into the intake.. The shopvac came in very handy keeping things clean.
Old Sep 17, 2009 | 08:20 PM
FordNFishinLover's Avatar
FordNFishinLover
I didnt use sealant on mine.
To remove the gasket i just used a knife to get the main part of gasket than used a wire wheel on my drill to get all the rest off. Than cleaned the inside of covers real good.
Old Sep 17, 2009 | 09:18 PM
roadrash63's Avatar
roadrash63
hey dpellicone
did you have to remove the fi manifold ?
ty
Old Sep 17, 2009 | 10:13 PM
ctubutis's Avatar
ctubutis
I used Hi-Tack to "glue" my new rubber gaskets to the valve covers, but didn't use any
sealant at the heads and it seems to be working fine.
Old Sep 17, 2009 | 11:08 PM
86stepsideF150's Avatar
86stepsideF150
I just did mine fairly recently. You do not have to remove the upper intake manifold. You can sneak it out. Sealant is unnecessary for sealing purposes but it is helpful to use a little just to hold the new gasket to the valve cover during installation.
Old Sep 18, 2009 | 05:14 AM
roadrash63's Avatar
roadrash63
thanks 86stepsideF150
Old Sep 18, 2009 | 04:45 PM
dpellicone's Avatar
dpellicone
Yes i had to remove the upper Intake. was not that bad. had to get a t-40 screwdriver to get the one of the inner bolts.
Jesser02EX
35
Jul 14, 2014 12:17 PM
TexasEX2K
Jul 5, 2012 10:46 PM
Splash67
May 17, 2012 12:18 PM
jcardwell3rd
23
Jul 6, 2011 06:57 PM
smkf100
Oct 1, 2009 10:03 PM
