1978 - 1996 Big Bronco
hard shifting
Old Jul 2, 2006 | 03:46 PM
captainl67's Avatar
captainl67
Question hard shifting
just baught a 1994 ford bronco xlt the check engine light comes on and the idle goes up / the trans shifts real hard too hard! any body got a clue whats going on? i didnt give much for it but i want to fix it up.
Old Jul 2, 2006 | 03:59 PM
althund's Avatar
althund
have to read the codes the check engine light is letting you know about before you do anything. It could be something simple.
Old Jul 2, 2006 | 04:03 PM
captainl67's Avatar
captainl67
yes im going to get a code reader a friend said his tps caused hard shifting in histang.but didnt showe up on the code reader ever here of that before?
Old Jul 2, 2006 | 06:26 PM
althund's Avatar
althund
Ya, the codes don't tell it all. I never had that in my truck before, but have had it in two cars. I was the mass air flow sensor. Caused all sorts of fuel and vacuum issues. Expensive fix ($200). Hope it's not that. Another one of mars also did that, and it was a broken wire at the computer. As you can see, my luck with cars isn't very good.
Old Jul 2, 2006 | 08:00 PM
masseysbronco's Avatar
masseysbronco
The computer will tell you if it's the TPS or any other sensor. Go ahead and check for codes before you buy anthing you don't need.
Old Jul 2, 2006 | 08:19 PM
captainl67's Avatar
captainl67
yeah im goin to i just got to buy a scanner cause the light wont stay on to get one of the parts house to read them .
Old Jul 10, 2006 | 09:41 PM
msd0912's Avatar
msd0912
I am almost 100% sure its your throttle postion sensor (TPS) its located under your throttle body. You should be able to do it yourself. Most shops will charge about $160 to fix. A new TPS costs about $30. I just changed mine out on my 1993 Bronco. It runs perfectly now, shifts great!
Old Jul 10, 2006 | 11:07 PM
greystreak92's Avatar
greystreak92
captainl67,
You don't even need the code reader for your truck to get the codes. All you need is a way to jump the self test single terminal connector (PURPLE/WHITE) wire and the EEC-IV test connector terminal with the (GREY/RED) wire together. Both are located on the driver's side of the engine bay near the hood spring. Jump these two wires together and turn the key ON. The codes will flash out via the "Check Engine" light. For a complete description of the procedure check www.fordfuelinjection.com or get a Haynes manual for that covers your model year.
Even if you DO buy a code reader, getting the codes from the EEC-IV computer will save you tons of time guessing or replacing components that MIGHT be the problem.
BTW, there are TWO tests that can be administered. KOEO (Key On Engine Off) and KOER (Key On Engine Running). You should run BOTH just in case the problem does not generate a code in one.
Old Jul 11, 2006 | 02:26 PM
captainl67's Avatar
captainl67
thanks greystreak iwas trying to come up with the money to buy a code scanner but this is great thanks every one ive been doing mechanic work for years but got out of it full time some years ago and never really had any formal training just another third generation hillbilly mechanic . but im enjoying this forum thanks again.
Old Jul 11, 2006 | 02:27 PM
captainl67's Avatar
captainl67
auto zone and advance wouldnt do a keoeo test !
Old Jul 11, 2006 | 03:07 PM
Kemicalburns's Avatar
Kemicalburns
well know you know who not to buy anything from. i wouldnt give them any of your business after that crap. it takes all of 5 mins , how lame
Old Jul 11, 2006 | 03:20 PM
captainl67's Avatar
captainl67
yea its pretty lame but he said the light has to stay on continualy or he cant read it i tried to tell him how but there not the smartest bunch and thats at both auto zone and advance . pep boys wants 20.00 bucks. yeah rite
Old Jul 14, 2006 | 02:39 PM
captainl67's Avatar
captainl67
Thumbs up
well i broke down and baught a tps from advance but it cured the problem they gave me a discount because i told them about you guys and the manager apoligized so it fixed the trans is shifting good the light is out thanks again you all did help greystreak im now going to be a supporter
peace
Ceaumar
Mar 8, 2019 09:37 PM
srsparky32
31
Nov 1, 2016 09:51 PM
greentruck72
Apr 30, 2016 01:23 AM
hail destroyer
Apr 29, 2016 05:42 AM
Gatordog
Apr 27, 2016 07:12 AM
