King pin removal
King pin removal
I'm going to have to swap out one of the spindle arms on the "new" '78 front end (disks) I have for my '68. The shoulder where the seal runs and right below that on the spindle are pretty badly trashed. So, now that I have the locking pins out, what do I have to do to get the king pins out? I'm trying to drive it out from the top with a 2# blacksmith's hammer and a brass rod and all that's happening is the rod is getting shorter and fatter.
Thanks,
Dan Blackwell
Thanks,
Dan Blackwell
on
King pin removal
Red 68! Take these axles down to a shop that has a press and have the pins and bushings pushed out. And while you have them off install the new pins before you put the new axles on the truck. It is nicer working on a bench and a lot easier to get those thin shims in.
William in Atlanta
William in Atlanta
King pin removal
[font size="1" color="#FF0000"]LAST EDITED ON 26-Aug-00 AT 10:35 PM (EST)[/font][p][FONT COLOR="#0000ff" SIZE="+1" FACE="Veranda"]
If your real ambitious you can make a small jig that will allow you to use a hydraulic bottle neck jack to press these pups out. Most times some heat is necessary too. As was suggested, the "hydraulic press route" is really the best way to go. Here is a picture of the jig:
[/FONT]
http://www.sonic.net/~sdelanty/show-n-tell/press02.jpg
(Photo and jig design courtesy of FTE list member Steve Delanty. A link to his site is found on the main site's link page)
http://members.aol.com/tbeeee/page/signature.gif
[FONT COLOR="#ff0000" SIZE="+2" FACE="Bassett"]Stock Man[/FONT]
[FONT COLOR="#0000ff" SIZE="-1" FACE="Tahoma"]
1967 F250 4wd Mini Fire Truck
1967 F-250 FE 390 4wd LWB Styleside
1966 F-250 I6 240 2wd LWB Flareside
http://www.hometown.aol.com/tbeeee
[/FONT]
on
King pin removal
If its stuck bad enough to mushroom or fatten up, lots of heat may help but you'll just end up with a heart attack getting them out! Undo the i-beam, (if you look under the truck, it bolts on pretty simply) and take it to a shop and have them pressed out. When kin pins come out in 10 minutes (I've had that pleasure), its not worth the trouble to pay a shop. On the other hand I've also had really stuck pins in a truck that tight steering and paid a shop to press them after burning myself on red hot metal and pounding with a large hammer.
If you're looking at 30-60 minutes each, a shop will press them out for $20. I'd say $20 is a good trade-off for an hour or two of busting your knuckles!
Ken Payne
Ford Truck Enthusiasts Admin
[img src="/clipart/logosmall.gif"]
(Click on Profile/Signature to add your own custom signature)
Ken Payne
King pin removal
Thanks for the advice. I just didn't know whether to expect this thing to come out with a reasonable amount of force or if it's one of those things that can very easily defeat a set of hand tools. Since the problem pin is on an I-beam that's in the driveway and not yet on the truck the machine shop looks to be my best bet.
Dan Blackwell
Dan Blackwell
Dan Blackwell
07-07-1999 01:24 PM
