King Pins
Old Nov 29, 2013 | 07:27 PM
hivoltj's Avatar
hivoltj
King Pins
Hey guys, finally getting around to installing my Moog 8450B king pin set onto my new DJM Dream beams in the '77 1/2 ton. I don't remember there being the small grease seal when I took the old stuff apart, as well as the shims. I'm guessing you only need the shims if there is too much play up and down but I'm at a loss as to where the two grease seals go?
Anyone have an exploded view of the king pin/spindle set?
Old Dec 2, 2013 | 01:31 PM
hivoltj's Avatar
hivoltj
Looks like from searching it goes between the top of the I-beam and knuckle. Would still love an exploded view if anyone has one.
Anyone know the thread and size of the grease caps? My threads must have gotten a little buggered swapping out bushings and I need to clean them up.
Old Dec 2, 2013 | 09:36 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's an exploded illustration of the twin I-beam front suspension. The grease seal is basic p/n 3178.
File Type: pdf
Old Dec 3, 2013 | 11:54 AM
hivoltj's Avatar
hivoltj
Thank you sir!
Old Dec 10, 2013 | 11:22 AM
hivoltj's Avatar
hivoltj
No luck finding a tap to clean up these threads with. I mic'd the cap with a caliper and it is 1.053" where the threads are, appear to be coarse. I'd imagine a 1" thread tap or chaser is going to be pretty expensive. I might cut some grooves into one of the old caps and try to use that as a chaser...
Old Dec 10, 2013 | 06:12 PM
ChaseTruck754's Avatar
ChaseTruck754
That might just work for what you need & is definitely worth a try.
Old Dec 16, 2013 | 01:07 PM
hivoltj's Avatar
hivoltj
It was a bitch but it eventually worked.
Worth noting : The grease seal does not go in between the knuckle and I-beam, but fits the knuckle on the bottom side of the top king pin bushing. You need to leave a 1/8" gap or so at the bottom of the bushing for the seal to fit into. I had driven mine in flush and had to pound them back down a hair to make room for the seal.
qman
17
Jun 25, 2015 03:40 PM
newguy399
Apr 14, 2014 06:39 PM
Nathan Plemons
Nov 24, 2010 09:43 PM
DT 466Man
Jul 15, 2005 07:56 PM
rog_j
May 2, 2003 05:51 AM
