1995 E150 TPS replacement
Old Jul 1, 2006 | 09:32 PM
ptt's Avatar
ptt
I think I may need a TPS replaced. It's on a 5.8L V8. Does the throttle body need to come off like the Haynes manual says? I've had the idle solinoid off and that was not bad as for accesability. Just hoping I can get it off without removing the TB. Thanks
Old Jul 1, 2006 | 10:03 PM
pfogle's Avatar
pfogle
You will need to remove the throttle body. The TPS is held on with two screws, and it's located on the bottom of the throttle body.
almonyspm1
Jun 4, 2013 06:19 PM
Chaos 95
20
Nov 21, 2012 10:32 PM
halaferd
22
Sep 22, 2012 10:49 AM
eakanator
Jun 4, 2002 07:03 AM
