87 e150 xlt - starts only in perfect weather
This is the second time posting my problem - the first time I thought it was a fuel problem which I found it wasn't - thanks to those who helped me, especially subford!
The van will not start in foul weather... whether it's too cold, too hot or rainy. If I try to start it, sometimes it'll make like it's dieseling right after cranking for a couple of seconds. However, it'll start no problems on dry, sunny days around 70 degrees.
I have fuel at the rail - am thinking it's the autozone ignition module I put in last year or coil or both. (haven't checked for spark) Called the Ford dealership and they advised both coil and module be replaced at the same time.
Just wondering if anyone else has had a similar experience with a fix before I start getting dirty... thanks ~rich
Sounds like my old '87. Wouldn't start in damp or rainy weather. On a foggy morning it would give me trouble. I would open the hood, let the sun shine in and it would fire right up.
The plug wires were absorbing moisture and shorting out. Moisture was getting in the cap which had a slight oil film on it, and probably traces of carbon.
I'd replace the wires, cap and rotor. I'd also replace the plugs with Motorcraft® brand. Mine didn't like platinums.
Check the choke.
Check the choke.
Originally Posted by van-man
last year on cap, rotors and wires - plugs are bosch platinums have about 10k on them
Second, I'll bet that your cap has two snaps that hold it down, right? I can't tell you the number of times that I've seen a cap with one of the snaps loose, broken, or missing. If that's the case, then the inside of the cap and the rotor are going to be corroded. Any humidity at all is going to make the problem even worse. Here's what I'd do. I'd take the cap and rotor off and inspect them. Check to make sure the cap was snapped down snugly. I'd say you'll find corrosion on the cap and rotor contacts. If it's not very bad, you *might* get away with cleaning them. It's probably just easier to buy a good quality cap and rotor kit. Also, be careful about quality on those parts as well. I've seen some brands that the contacts inside the cap were almost always installed crooked. What good is that?
Lastly, I'm sure you're going to get a few more people say what someone else already did. Our Fords don't seem to like Bosch plugs in particular. I know they're more expensive, and come highly promoted. I bought a set of Bosch Platinum +4's when the first came out, and put them in my 75k mile Ranger 4.0. It ran worse with the expensive Bosch's than with the original Motorcrafts. I finally replaced them with Autolites, and it smoothed out considerably. I know that's just antecdotal evidence, but over the last few years, I've heard a LOT of people say similar things.
Good Luck!
OK, thanks - but I did a quick check for spark coming from the coil and found it's not sparking when cranking ( van is in a no-start mood right now )
HOWEVER, after I turn the key to OFF, it throws nice sparks in equal pulses for as long as the fuel pumps are running AND THE MOTOR IS NOT TURNING! I thought the distributor had to be turning for the ignition circuit to pulse? I guess this explains the dieseling effect I was getting...
zap - zap - zap.
Also, it sounds like there's a relay that's clicking in sync with the spark or it may be the coil or possibly the coil grounding out but there are definitely two distinct zapping / clicking noises in sync.
If someone had a diagram of the ignition circuit for this model van I would greatly appreciate it! Thanks a lot guys (and ladies) ~Rich
zap - zap - zap.
**UPDATE**
Spoke with ford tech on the phone - although they no longer have working knowledge of the older vans and couldn't say what the problem was, he vaguely remembered that EEC-IV ignition modules and coils should be replaced together. Something I didn't do.
Today, bought new module and coil, discoed battery for 30+ minutes to reset computer, installed and reset timing, sprayed a little carb cleaner down the TB for good measure - WORKS LIKE A CHAMP!
Thanks to all who helped me. Good luck with your vehicles. ~Rich
