Transfer case problem
Old Jul 3, 2006 | 04:54 AM
  #31
460's Avatar
460
Sorry for the hijack here, but maybe someone could help me with a post I made a few days ago... and has only 17 veiws at the time I'm posting this. I think I understand what I need to do, I'm just looking for some confirmation and possibly advice. It also has a pic of a 205 with the short adapter. https://www.ford-trucks.com/forums/s...d.php?t=504989
Thanks guys.
End of hijack.
Old Jul 3, 2006 | 06:16 AM
  #32
Jmudder79's Avatar
Jmudder79
If your looking to swap a 205 for your 203 the easiest thing to do is go to the junkyard and find a donor truck. That way you will have everything you need right there. I did the same swap in my truck years ago and it was easy. I just found a truck with a C-6 and NP-205 and took them both and swapped them in as a pair. That would be the easiest way to go.
Old Jul 3, 2006 | 06:49 AM
  #33
RCrawler's Avatar
RCrawler
I replied to your other post in the transmission forum.
This is where I think that posting in the specific year and model forum for drivetrain or engine questions is better than in the specialty forums. In my experience, there isn't as many viewing in those forums and there will be better response posting to the larger ones such as this one.
Jason
Old Jul 3, 2006 | 06:58 AM
  #34
Jmudder79's Avatar
Jmudder79
The Offroad and 4x4 forum also wouldn't be a bad place for t-case related questions.
Old Jul 4, 2006 | 01:16 AM
  #35
460's Avatar
460
Thanks. The "Clutch,Transmission, Differential, Axle and Transfer Case" forum sure seems dead to me too.
Old Jul 4, 2006 | 05:34 PM
  #36
RTM's Avatar
RTM
All F150, F250 and F350 trucks got the short adapter and all Broncos got the longer adapter. Now I have for gotten what the ext. cab got and the crew cab.
I have read many times that one just needs to pull the 203 and bolt the 205 in place of course drive shafts will have to be redone. I recall something about the trans pan and the front drive shaft but I am not sure what that was. I have not done the swap but in order to go from the short adapter to the long you have to swap the output shafts in the trans.
djmichael24951
Mar 3, 2014 05:22 AM
aval1629
Feb 4, 2011 07:29 AM
bigjohnsonross
Feb 23, 2009 01:23 PM
powerplay
Aug 11, 2006 11:56 AM
f150_514ci
Offroad & 4x4
39
Mar 10, 2005 11:34 PM
